Old 10-15-2022, 10:10 AM
JUDGE3 JUDGE3 is offline
Default Air compressor isolation mat
my compressor has the solid ring base & 4 feet mounts. so separate isolator pads won't work. anyone have theirs on one of those horse mats from tractor supply?
worth it to have on a pad or mount to the floor without it? I mounted my old one directly to the floor and was definitely some noise transmitted.
also do the dixon air hose end repair fittings work well?
Got the Emax compressor yesterday, have to run 6 gauge and a 40 amp breaker yet. not a fair comparison to my old one but this one is more heavy duty and better quality in every way. it looks great, hopefully it will run great. shipped all the way from the east coast undamaged couldn't believe it.
Old 10-15-2022, 11:43 AM
Stuart's Avatar
Stuart Stuart is offline
Does it really need to be supported around the entire perimeter of that base ring? I'd think you could use a separate isolator pad under each bolt hole and it would be fine. Hockey pucks with holes drilled in the center is one cheap and easy way to do it.
Old 10-15-2022, 11:54 AM
Cardo's Avatar
Cardo Cardo is offline
I used some concrete studs and 4 shock bushings. Put a stud in the floor, put a shock bushing on the stud, walk the compressor onto / over the studs, and tighten it down.
"I know just enough to keep me here, but not enough to get me out"
Old 10-15-2022, 11:59 AM
Sirrotica's Avatar
If the noise bothers you, building a small shed outside of the garage is the best thing I ever did to not have to listen to the compressor run. If I ever get all the necessary things finished at this house, I will build a small shed for the compressors.
The air intake has a lot to do with compressor noise, I packed the air cleaner in one of my compressors with foam rubber, (same type small gas engines use for air cleaners) that helped a lot.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-15-2022, 12:17 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
That`s how I did mine. 60 gal upright.
Old 10-15-2022, 12:40 PM
78w72 78w72 is offline
i have a 60 gallon upright compressor, i use 4 pieces cut out of a thick truck tire, about 4" x 4" each with no bolts or anchoring to the floor, it hasnt moved at all for 10+ years.
Old 10-15-2022, 01:26 PM
Murf Murf is offline
I probably shouldn’t admit it but I left mine bolted to the pallet. I hooked into my piping with a hose to isolate vibration. Been that way for at least 20 yrs. Now watch!��
Old 10-15-2022, 03:03 PM
Bills Auto Works's Avatar
Bills Auto Works Bills Auto Works is offline
My Atlas-Copco 5HP v-twin with 80 gal tank is 20+years old & it is also still bolted to the pallet I bought it on! Admittedly the pallet under mine is smaller than the one pictured by the OP.
I have no excessive noise or vibration, but my shop is large (56 x 88) so I don't work very close to the compressor. Every once in a while, I will reach over & hit the valve on the bottom of the filter/water separator to let the little bit of water out & the compressor will kick on & scare the sh1t out of me! LOL
God Bless
Bill
https://www.jalopyjournal.com/forum/...closed.614419/
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society"
Your QUALITY Pontiac Transporter Since '83
1955 Chevy Alt. W.B. Gasser
1955 Nash Ambassador Cust Lemans
1957 T-Bird
1964 Grand Prix
1966 Catalina Conv
1966 Ambassador DPL 2dr
1966 Ambassador Cust. 2 DR
1967 Marlin
1967 Toro
1973 Nova Chassis Car
1992 Jag XJS Conv
1992 Jag XJS Coupe
2007 Cad XLR-V Supercharged Roadster
2008 Avalanche Southern Comfort Edition
The Following User Says Thank You to Bills Auto Works For This Useful Post:
Old 10-15-2022, 05:20 PM
turbo69bird's Avatar
Mines still on the pallet too. Never did anything but plumb the line and plug it in . That was 2012 still there doing fine. It Is far quieter then my bolted down compressor at my hangar. If I wanted it quieter I’d probably use some 2 inch foam board and make a box around it with air holes but it doesn’t bother me.
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
Old 10-15-2022, 05:34 PM
Old Goat Racer's Avatar
I slipped 3 of these under each leg 3 years ago . Hasn't moved.
https://www.ebay.com/itm/22248849843...3ABFBMku_P2Ptg
Everybody knows somthin.
Nobody knows everything !
Old 10-15-2022, 05:45 PM
Tom Vaught's Avatar
Boost Engineer
I bought some mounts from A Hardware store that hat a single bolt mount on the top and a two bolt mount that I attached to my wooded skid. Works great and as was posted the Induction Noise is much louder vs the compressor possibly moving around.
The new barn will have a dedicated compressor room to make it even quieter. The horse blanket stuff is not the right stuff to use.
Plus the newest adds from Harbor Freight say do not allow your pets to be near it. Typical for Chinese cheap HF stuff.
Tom V.
Old 10-16-2022, 04:57 PM
dataway's Avatar
dataway dataway is offline
Might not be right for everyone ... but I welded up a carriage for mine so I could roll it around if necessary and mounted it to the carriage with isolators. Good quality casters will roll around 600 lbs without much trouble.
If I need to get behind it, get it in the open to work on it, clean it etc. .. just unplug, pop off the connections to the air system ... roll it out of the way. Also gets the drain valve up off the floor so it's easier to get too.
Old 10-16-2022, 05:30 PM
Simple Man's Avatar
Mine is still on the pallet, also. Seems to work out good 20 years later
be a simple...kinda man.
Old 10-16-2022, 06:52 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
[QUOTE=JUDGE3;6379871]my compressor has the solid ring base & 4 feet mounts. so separate isolator pads won't work...
/QUOTE]
My compressor has the same type of base. I was able to use vibration pads but had to place some flat steel on the top of the pad. The steel is under the ring but without it the ring was crushing into the pad. My Ingersoll said not to leave it on the pallet and the unit must be firmly mounted, however, it appears that a lot of guys use the pallet with no problem. I bolted mine only because I wanted to use my new hammer drill.
Old 10-16-2022, 07:21 PM
Sirrotica's Avatar
Even after 15 plus years, of sitting on the shipping pallet it has had no effect that I can determine, but it's still noisy.
Back in the 70s I put mine in it's own shed behind the garage, that was the absolute best answer to compressor noise. I ran the drain valve into the garage so I didn't have to go outside to drain the tank.
Most likely how I'll set mine up at the current garage. When I bought the house it had 2 compressors already here, and I still have my compressor at the old house, so I'll end up with 3, when I get everything situated. I'll have 2 in tandem for the big garage, and one for the storage garage.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-16-2022, 08:05 PM
72projectbird's Avatar
My 60 gallon is also still bolted to its pallet. No issues.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 10-17-2022, 03:08 PM
Default Mounting & vibration dampening a ring base 4 feet compressor
Glad folks that left there's on a pallet had it work out. I would never do that.
don't know what horse "blanket" from harbor freight is. not what I'm talking about for sure.
I can see how using isolator 4" x 4" pads only at the feet on a ring base would not distribute the weight evenly and want to dig in without adding steel.
I used "stall mat" -for horses- from Orscheln's. believe tractor supply has it as well. very strong -and heavy!- stuff. a 4x6 mat of it is a load believe me. its 3/4" thick, perfect for the compressor isolation. does not dig into the mat at all, even walking the compressor around on it does not gouge it. I cut a 2' x 2' piece for the entire base to sit on distributing the weight evenly and hard anchored it to the floor.
Figured if I spent the extra bucks for a quiet running compressor I may as well isolate the base from any possible vibration. 1/2" anchors in the floor.
The Following User Says Thank You to JUDGE3 For This Useful Post:
Old 10-17-2022, 08:57 PM
SRR's Avatar
SRR SRR is offline
Looks great!
― Calvin Coolidge
Old 10-17-2022, 09:29 PM
chevymad chevymad is offline
I used horse mat for mine as well. Never bolted it down, just set it on the mat. Doesn't seem to move at all.
Old 10-18-2022, 05:37 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Mine is still on the shipping pallet. Been that way for close to 30 years now. I've thought about anchoring it down. Still thinking I guess.
