Old 10-16-2022, 10:07 PM
twoponchos's Avatar
twoponchos twoponchos is offline
Default Finished paintjob with Wicked Colors water based paint
After countless hours of bodywork and sanding, it's finally in its new color. It turned out super well considering it was done in my dirty shop in a makeshift temporary spray booth.
Pearl blue with a white flake roof.
link to video below.
https://youtu.be/7E0hj79BYoU
ID:	600581   Click image for larger version
ID:	600582   Click image for larger version
1974 LEMANS
-dual 4bbl 455
-bench seat
-4 spd
The Following 4 Users Say Thank You to twoponchos For This Useful Post:
Old 10-17-2022, 12:49 AM
turbo69bird's Avatar
Createx is right near me and I know the owner went to high school w him. Good guy. They still don’t have an isocyanate free clear that’s good though do they? Isocyanates are very dangerous. Their base coat is isocyanate free according to them .
BTW the car looks great . Hard to see metal flake in the garage needs sun. My airplane is metal flake vinyl wrap like that.
This stuff
https://m.youtube.com/watch?v=rrn6PWyh5Kw
Probably just like your car.
Your car looks fabulous you did an amazing job.
Matches my airplane perfectly !
960 HP @ 11 psi, 9.70 at 146.
Old 10-17-2022, 04:16 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Looks great!
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 10-17-2022, 09:44 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Came out nice!
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
The Following User Says Thank You to lfdsteve For This Useful Post:
Old 10-17-2022, 10:22 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Good job and nice color!
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 10-17-2022, 11:35 AM
webfoot's Avatar
webfoot webfoot is offline
Nice job!
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
The Following User Says Thank You to webfoot For This Useful Post:
Old 10-17-2022, 11:36 AM
What did you use for a clear? Or did you mix the color into clear?
Old 10-17-2022, 11:44 AM
beautiful...not too many of those around here
Old 10-17-2022, 05:37 PM
Nice. I like seeing cars guys paint themselves. With that, we can live with imperfections if they show up.
The Following User Says Thank You to tjs72lemans For This Useful Post:
Old 10-17-2022, 06:26 PM
cnc's Avatar
cnc cnc is offline
Wow looks beautiful....see u r in Sarnia..u just out side the city..I'm in London....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
The Following User Says Thank You to cnc For This Useful Post:
Old 10-17-2022, 06:46 PM
twoponchos's Avatar
This stuff
They do produce a iso free waterborne clear, but it does not withstand the outdoor elements too well from what I understand. It is loved by model makers, and hobbyists though.
This is my 3rd full paint using their products and I just adore it.
The roof is amazing in the sun, however my camera just can't seem to catch it.
Your plane is gorgeous! Great minds eh?
1974 LEMANS
-dual 4bbl 455
-bench seat
-4 spd
Old 10-17-2022, 06:49 PM
twoponchos's Avatar
It can be top coated with any clear. I used a generic 4k clear from my local auto paint supplier.
1974 LEMANS
-dual 4bbl 455
-bench seat
-4 spd
Old 03-15-2026, 11:03 PM
Realize this is an old thread but there's been a lot of new advancements in clear over your side of the world
Also ISO free epoxy primer surfacers
They did t get rid of isocyanates for no reason anyone who has been sensitized can tell you .
https://www.limelinepaintsupply.com/...tal-light-grey
ISO free 707 clear
https://conceptpaints.com.au/sites/d...%20Clear_1.pdf In Australia
Sherwin Williams -
Ultra-FIll® DTM Isocyanate (ISO)-Free Primer/Surfacer
Premium Ultra-Fill HS is a Direct-to-Metal (DTM) ISO-Free Primer Surfacers NP75/NP74W are free of lead and chromate hazards.
Direct-to-Metal (DTM) ISO-Free Primer Surfacers free of lead and chromate hazards. As high build surfacers, with excellent gloss holdout and sanding characteristics, NP75 / NP74W / NP76 can be used in Collision and Fleet markets. NP75 / NP74W / NP76 provide excellent bare metal adhesion and corrosion protection without the need of an etch primer and meet National Rule VOC regulations of 4.6 Ibs/gal.
Why do we need Isocyanate free coatings?
Research into a polyurethane network without exposing the applicator to isocyanates has also been recently developed.
Cyclic carbamates have been found to convert to aliphatic polyurethane systems through reacting them with polyamines, thereby eliminating the potential of isocyanate exposure to the applicator. One of the drawbacks to this type of approach is the complete overhaul of chemistry and starting materials, which does not result in a network with original chemical characteristics and properties of a standard polyurethane system.
V650 Isocyanate Free
Polyurethane
Due to the lack of an available
