Old 10-23-2022, 12:06 PM
GREGGDOG GREGGDOG is offline
Default 71 Trans Am mystery wire....?
Trying to help a friend with his HO 4spd.
Not sure what/where the brown striped connector plugs into?
Car in non-ac. I thought it was for the blower motor connection under fender liner but not sure that is for a/c cars only.
Old 10-23-2022, 02:52 PM
Kenth's Avatar
Kenth Kenth is offline
IIRC it should be plugged to the Low Brake Fluid switch.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-23-2022, 03:11 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
That plug-in is if the car has a turbo-400 automatic transmission. The passing gear kick-down is controlled via an electric switch mounted inside the car on a bracket mounted above the gas pedal. On a 4 speed car that wire would not be needed.
Do not cut it, coil it up and tape it off neatly along one of the firewall holders.
Peter Serio
Owner, Precision Pontiac
The Following User Says Thank You to Peter Serio For This Useful Post:
Old 10-23-2022, 10:34 PM
Default Thanks
Thanks for the replies. Yes Peter, was the extra auto trans kickdown plug. He appreciates the help.
The Following User Says Thank You to GREGGDOG For This Useful Post:
