Old 10-31-2022, 10:47 PM
64speed's Avatar
64speed 64speed is offline
Default Valve adjustment
Rebuilding this 468 after the failure. I am using HFT lifters instead of a roller mostly because of cost but also cam availability. I am reading about the EOIC method of adjustment. I think I am picking it up but I have never adjusted valves like that. To be honest I’m the past I just twisted each one between my fingers till I felt resistance and tightened the nut slightly right there without worrying about cam location because I was under the impression that Pontiacs did not have adjustable valve trains (never used poly locks or roller rockers. I am using poly locks and roller tip rockers this time). How do I do this to insure the lifters are turning. I know there is no guarantee against failure but if this one fails I’m gonna cry LOL
Old 11-01-2022, 12:58 AM
lust4speed's Avatar
First off, I never liked twisting pushrods, and found that starting loose and going side to side (fender to fender) tightening down the polylock worked much better for me. Much easier to feel a slight clunk back and forth slowly going away on the rocker arm than determining when friction slightly increases spinning them.
You must set each valve separately if using EOIC. Really pretty simple. Using the firing order start with #1 exhaust and watch for the #1 intake rocker to just start to lift and then go to zero lash plus a half or whatever setting you are using on the intake. The next is #8 and only a partial turn of the crank until you see the #8 intake rocker start to come up. Then continue through the firing order for the rest of the intakes.
Then go back to #1 intake valve and watch for it to open and almost close and then adjust the exhaust. Like above just go through the firing order and you are done. As a precaution, take a flat edge and lay across the polylocks. All polylocks should touch or almost touch the flat edge. If you get a polylock sitting too high or low, then go back and check that adjustment.
One full revolution for setting intake and one full revolution for setting exhaust and you are done.
Mick Batson
The Following 2 Users Say Thank You to lust4speed For This Useful Post:
Old 11-01-2022, 07:28 AM
68WarDog's Avatar
68WarDog 68WarDog is offline
David, great to hear your new combo is coming together. What length pushrods are you now running?
Old 11-01-2022, 07:52 AM
chuckies76ta's Avatar
Mike: Just a little confused here.
You meant Exhaust rocker just start to lift, set intake . Right?
I know you know what your talking about. Thanks
Old 11-01-2022, 09:58 AM
track73 track73 is offline
If you don' t have the valley cover on it's easy to see if the lifters are on the base circle. I adjust the valves before I install the cover and intake. If that isn't an option you can also set the number 1 piston at top dead center on the power stroke and set both valves,. then 1/4 crank turn and do number 8 and so on.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 11-01-2022, 10:19 AM
jwhit jwhit is offline
for years ive done this way eo ic
when ext starts to open adjust intake when intake starts to close adjust ext
never had issue
Old 11-01-2022, 10:46 AM
ta man ta man is offline
never had issue
Thats how I do it, I can run thru the valves in less than 10 minutes. I also pull all my plugs so the starter spins easier and also have a bump wire tapped into my starter wire. So I can simply bump the engine from the front.
Old 11-01-2022, 01:57 PM
hope this dont get me band from fourm but i always put ford style solenoid
on fender well close to battery so wire running to starter is only hot when starting (this started when i drop wrech about 30 years ago and it shorted on starter and i was rushing to get battery unhooked ) now i can have easy spot to pull power and hook my remote start button real easy for adjusting lifters
The Following User Says Thank You to jwhit For This Useful Post:
Old 11-01-2022, 02:48 PM
never had issue
Isn't it: Intake valve just about fully closed? Then adjust Exhaust. Just curious. The exhaust is never a question, as It is always written as when it starts to open. The intake on the other hand, I've read fully open then just starts to close, or intake valve fully open then just about closed. some say fully closed. Hmmm. Thoughts. Am I overthinking it?
Old 11-01-2022, 03:06 PM
Greg Reid Greg Reid is online now
This might sound crazy to you guys but I saw a guy do this once and I tried it. Worked for me. He simply adjusted every loose rocker until it was snug. Turn one quarter rotation, do it again, one quarter rotation, do it again and then one last time for four quarters. Now, go through the entire rotation again, one quarter at a time. You're done.
Is that crazy? I don't know but it works.
Old 11-01-2022, 03:40 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have always done it single cylinder at a time. That way I can remember which ones I did!
Skip Fix
Old 11-01-2022, 04:10 PM
Kenth's Avatar
Kenth Kenth is offline
I like it simple:
The correct way is turn the engine till you have compression on #1 cylinder.
Once you have it on TDC, you adjust the following valves #1,3,4,8, exhaust & #1,2,5,7, inlet.
Then you turn the motor over once back to the timing mark, you are now firing on #6, you adjust #2,5,6,7, exhaust & #3,4,6,8, intake. For hydraulic lifters you back the rocker off till you have play, then you take out all the slack between the push rod & rocker, then you tighten the rocker nut one full turn. This will place the hydraulic lifter plunger half way through it's travel.
After driving around for a while i´ll do a running adjustment, loosening one rocker nut at a time until the rocker clatters, snug it up til it´s quiet and then a full turn.
For this it helps having a valve cover with a cutout roof and some clips on rockers covering the spurt holes.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-01-2022, 04:23 PM
lust4speed's Avatar
...and watch for the #1 intake rocker to just start to lift...
Thanks for correcting my swapping the intake for exhaust. It should read "...and watch for the #1 exhaust rocker to just start to lift...
Hate when that happens
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 11-01-2022, 05:14 PM
NeighborsComplaint's Avatar
That's how I do mine except with random rotations of the crank. When they're all snug (0 lash), I go 1/2 turn and lock them down with my polylocks where they stand. Never been a problem, no tickers.
Triple Black 1971 GTO
The Following User Says Thank You to NeighborsComplaint For This Useful Post:
Old 11-01-2022, 07:02 PM
grivera's Avatar
grivera grivera is online now
http://www.wallaceracing.com/valvelash.htm
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
The Following User Says Thank You to grivera For This Useful Post:
Old 11-01-2022, 08:47 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is online now
never had issue
Same here. Works great
Old 11-01-2022, 09:25 PM
cnc's Avatar
cnc cnc is offline
Originally Posted by Kenth View Post
I like it simple:
FWIW
Same here for adjusting valves I have a cheat sheet for it...lol
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 11-02-2022, 07:44 AM
i let intake fully open and as soon as it starts to close i adjust ext
Old 11-02-2022, 08:53 AM
grivera's Avatar
I'm sure you know adjusting the lifters properly and making sure all are spinning are two different things. When I've adjusted HFT lifters in the past with engine not running, I have seen the lifters and pushrod rotating. I suggest you put a mark on each pushrod with a Sharpie so you can verify they are rotating. Also, make sure the lifters don't hang up in their bores and that your camshaft endplay is set properly.
Will Rivera
Old 11-02-2022, 10:05 AM
78w72 78w72 is offline
I like it simple:
FWIW
ive done it this way also, thats the common SBC procedure. but i have read that once the cam duration gets too big, that way can become inaccurate since the lobe isnt in the ideal location, not sure how true that is maybe some of the experts can comment on that procedure on larger duration cams. it has worked on smaller cams i have done like a xe268, but for the OF roller i chose to do the EO/IC way for each valve.
also very important to follow what the lifter manufacturer says for preload, each lifter is different, a short travel for example doesnt use 1 full turn, some ive seen are 1/4-1/2 turn after zero lash.
