Old 11-02-2022, 04:30 PM
428 tempest 428 tempest is offline
Default 66 gto front end alinemnt specs.
Want to get 66 gto front end aligned but need specs shop don't have any Thanks!!
Old 11-02-2022, 05:44 PM
Kenth's Avatar
Kenth Kenth is offline
From 1966 Tempest Shop Manual:
Name:	66 wheel alignment.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-02-2022, 05:47 PM
Thanks Kenth
Old 11-02-2022, 06:12 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Just FYI, the shop manual for 1966 was written to assume the original bias-belted tires were still on the car.
The F.E. alignment #s for old school 1960s tires would not apply if you are running modern radial tires on your GTO.
Peter Serio
Owner, Precision Pontiac
The Following User Says Thank You to Peter Serio For This Useful Post:
Old 11-02-2022, 09:13 PM
bill ryder's Avatar
bill ryder bill ryder is offline
X2 Great point..
"Bill"!
Old 11-03-2022, 04:18 AM
Kenth's Avatar
Riding original bias-belted tires is a challenge with ANY alignment.
I have found radials runs quite well with original alignment specs on my 1966 GTO.
Donīt go crazy with camber and toe-in and youīll be fine. 0 to - 1/4° camber and 1/16" total toe-in is a good start.
With P/S you may want positive caster to gain some course stability, in most cases itīs possible to change from - 1 1/2° to + 1 1/2° by adding shims at the rear upper control arm.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
