Old 11-03-2022, 12:06 PM
MiamiHenri MiamiHenri is offline
Default 1967 GTO Matching numbers project runs drives
Here is a great start for a project 1967 real 242 GTO with PHS documentation. Has rare factory a/c, column shift and Mariner blue color. Has matching numbers YS block heads carb distributor trans original to this car. It starts up and drives around the block. No you can’t come and drive it home. The brakes working but need attention. I replaced the trunk floor pans and put a new gas tank. With small electric pump. Also put a self exciting alternator. Some wiring will need attention. Body has some rust however the frame is solid. I was planning to do a frame on restoration before I had medical issues. Has white seats not sure if the buckets are correct for the car. This is the one that can bring the money if done right. Taking huge loss $9500 in north Miami Florida
ID:	601635   Click image for larger version
ID:	601636   Click image for larger version
ID:	601637   Click image for larger version
ID:	601638   Click image for larger version
1968 Convertible Lemans running driving work in progress.
Old 11-03-2022, 12:13 PM
Default More pictures
More pictures, send message for other pictures.
ID:	601640   Click image for larger version
ID:	601641   Click image for larger version
ID:	601642   Click image for larger version
ID:	601643   Click image for larger version
Old 11-03-2022, 12:20 PM
Also I have a 1969 Lemans with a running 350 $3000 and a 1962 Catalina roller solid body no rust very straight car $2800
Old 11-03-2022, 04:06 PM
verackashotrods verackashotrods is offline
Default 69 Lemans
Any pictures of the Lemans
Old 11-08-2022, 01:16 PM
carcrazy carcrazy is offline
Pictures of the 62??
