Old 11-08-2022, 08:13 AM
Jimbobeast Jimbobeast is offline
Default Door jamb switches
With the Power Seat Back option were there two door jamb switches on each door (1970 GTO)? There is a dimple above the standard switch that I assume would be drilled for the second switch, and the two switches have different connectors. The photo shows the PSB switch connector. Thank you.
