Old 11-18-2022, 03:29 PM
helmerrock helmerrock is offline
Default Stuck Quadrajet
I picked up a 69 Quadrajet that is in good shape and complete. It may have been cleaned and left on a shelf for some time. The throttle shafts are stuck, the choke shaft is stuck and the rear two screws that on the air horn seem stuck. Idle screws are free and inlet threads are not stuck or corroded away.
I would like to save the carb without breaking, hammering, cutting. Any advice on how to free up the stuck shafts and screws? The body and air horn aren’t corroded and seem to have the original coatings in good shape. The throttle base is clean and not damaged or showing any major corrosion.
What’s the best way to save something lie this?
Old 11-18-2022, 05:11 PM
Half-Inch Stud's Avatar
Spray penetrant, heat it up, then worky loose.
Old 11-18-2022, 05:19 PM
25stevem's Avatar
25stevem 25stevem is offline
I can tell you how I did a 66 Carter AFB that might have been in even worse shape then your carb.
First to get the rear air horn screws out sit the carb up on a block of wood so it can’t rock.
Next get a tall socket that’s small enough to sit on the head of the screw ( I think I used a 5/16” ) then tap on the socket with a hammer.
This will allow you to jar the screw loose from the threads in the throttle plate.
For the next step to free up the two shafts one of the main things you will need is a electric heating pad.
If you have one then get a gallon of WD-40, a aluminum cooking pan that’s just big enough to hold the carb, it does not have to be tall enough to submerge the carb .
Next cover the heating pad with foil, set the pad on high , put the carb in the pan and pour enough WD-40 in to go half way up the carb.
Once the WD-40 gets up to about 105 degrees it will only take some 3 hours of the carb sitting in the pan to bust the two shafts free.
I do stuff for reasons.
The Following 3 Users Say Thank You to 25stevem For This Useful Post:
Old 11-19-2022, 04:52 AM
Kenth's Avatar
Kenth Kenth is offline
A propane torch will save your day.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-19-2022, 05:04 AM
Cliff R's Avatar
Cliff R Cliff R is offline
If the carb is stuck from getting water in and on it you are in trouble. If it's just stuck from years of sitting on a shelf a little penetrating oil and some heat from a propane torch as mentioned will free things right up.
I would recommend grinding the staked portion of the screws off the throttle plates and removing them then gently tap the shafts back and forth in both directions to free them up vs trying to twist them. The primary shaft in particular will twist out of shape easily and it's difficult to straighten. I get LOTS of practice straightening bent and twisted throttle shafts as the carb will NOT work well with twisted shafts in it no matter how good you do on the rebuild.
First order of business in your case is to remove the long screws so you can get the baseplate off the carb. Not a bad idea to soak it for a few days before attempting to free things up. Diesel or kerosene works well for that purpose, just drop it in a bucket with enough in to cover it. If the baseplate got water in and on it you may find removing the idle mixture screws much harder than the shafts. I've got a huge stack of baseplates with busted off mixture screws in them that weren't coming out despite your best efforts......
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 11-19-2022, 09:11 AM
The back pair of long screws can be the worst lockup ever.
Old 11-19-2022, 10:37 PM
77 TRASHCAN's Avatar
I usually use a bath of diesel and some ATF
Shut it off
Shut it off
Old 11-20-2022, 08:28 AM
shaker455's Avatar
shaker455 shaker455 is offline
Post up some pics and let's see its condition.
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 11-20-2022, 11:45 AM
Pics
ID:	602358   Click image for larger version
ID:	602359   Click image for larger version
ID:	602360   Click image for larger version
Old 11-20-2022, 11:48 AM
More pics
ID:	602362   Click image for larger version
ID:	602363   Click image for larger version
ID:	602364   Click image for larger version
Old 11-20-2022, 12:35 PM
burd burd is offline
Sounds like a Vicker carb
Old 11-20-2022, 01:26 PM
shaker455's Avatar
Originally Posted by helmerrock View Post
More pics
You'll be fine, just soak all the key spots with WD & BP Blaster
Give it time to soak and keep repeating
The Following User Says Thank You to shaker455 For This Useful Post:
Old 11-21-2022, 04:25 PM
Pav8427 Pav8427 is offline
Interesting.
Just pulled apart one that I have.
Same plant made just 20 days after this one.
