Old 11-20-2022, 01:57 PM
cnc's Avatar
cnc cnc is offline
Default Dash securing screws
The dash on my 73 Firebird has three nuts used to secure the dash at the glove box end while at the dash bezel gauge pod area there are three " screws " to secure it I think they were a 5/16 head on it but don't know the actual size ....does anyone recall the size of the screws ...thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 11-22-2022, 10:38 AM
78w72 78w72 is offline
yes, 5/16 head but not sure of the thread size, they are the same thread size/pitch as the screws used for other items in the dash, like the ones holding the gauges, headlight switch etc. but they might be a little shorter length.
i have probably a hundred of these screws if you need some.
Old 12-22-2022, 07:28 PM
cnc's Avatar
cnc cnc is offline
I’m sure I can get something here thanks for the heads up dash goes back in this weekend with the harness and cluster installed …gotta keep movin
