Old 11-27-2022, 09:51 PM
Question Battery jump packs
Have any of you real world experience with the new small lithium jumper packs? None of the ones that I've seen tested on line seem to be able to crank an engine for more than a few seconds (2-5). Is there one you have had experience with that works well on our older big displacement engines? If you have a flooded engine and a low battery a few seconds won't cut it. Thanks
Old 11-27-2022, 09:58 PM
blue67gtoragtop's Avatar
blue67gtoragtop blue67gtoragtop is offline
Great topic! I’ve been looking into getting one also, but can’t decide between the Nico lithium battery type or one like Dewalt or Jump-N-Carry.
Old 11-27-2022, 10:09 PM
tom s tom s is offline
I have a Nico and my son jumped his MBZ dsl with it,no issueTom
Old 11-28-2022, 12:16 AM
Which NOCO? It seems like the GB70 would be the least you would need. I have never seen one tested on a big V8.
Old 11-28-2022, 12:54 AM
R 70 Judge's Avatar
I have the CAT brand one from Costco. I’ve jumped 3 cars/trucks with it without recharging it. I bought it and charged it back in May 2022 iirc. It also has a built in compressor but haven’t tried that feature yet. It’s not small but it definitely works
https://www.costco.com/cat-1200-peak...100799044.html
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 11-28-2022, 01:00 AM
R 70 Judge's Avatar
Upon further review, apparently the sell a smaller version with only the charger. It’s rated at the same 1200 amps as the unit I have. It’s only $69.99
https://www.costco.com/cat-1200-peak...100831600.html
James
1970 Trans Am
Old 11-28-2022, 01:56 AM
turbo69bird's Avatar
I have a dewalt and it’s annoying as hell with its beeping and warnings . Don't buy one it’ll drive you nuts I’ve had two Schumacher units that were spectacular w no annoying noises .
960 HP @ 11 psi, 9.70 at 146.
Old 11-28-2022, 07:20 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I have this one: https://www.amazon.com/dp/B015TKUPIC...roduct_details
I've used it one time so far. Jumped a Dodge truck for a guy at work. Took it for not clicking the solenoid to spinning like a top. So far so good.
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 11-28-2022, 09:15 AM
1965gp 1965gp is offline
I have the big NOCO and can’t say enough good things about it. I can get several starts out of a charge- I think I’ve used it 8-10 times on a charge when I am shuffling cars with dead batteries.
Old 11-28-2022, 09:24 AM
Half-Inch Stud's Avatar
Stick to lead acid because lithium dies down (and out) in the winter. Or, what is the lithium cold-cranking Amps?
Old 11-28-2022, 09:42 AM
Stuart's Avatar
Stuart Stuart is offline
You're missing the whole point of the jump pack. A lead acid battery won't fit in your glove box.
Old 11-28-2022, 10:00 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I have this one for cars and motorcycles: https://www.amazon.com/gp/product/B09F9CR89W/
And we use this guy at work; it'll jump a completely dead 4-battery semi truck on a 40° morning. They make some smaller models that don't cost $1k.
Mike
The Following User Says Thank You to mzbk2l For This Useful Post:
Old 11-28-2022, 12:24 PM
tekheavy's Avatar
tekheavy tekheavy is offline
I've had this one for about 8 months and love it.
https://www.amazon.com/dp/B09HYVM6ZT...0+jump+starter
Wanted something a little bigger to handle the diesels truck at work so I bought this one today. Being Cyber Monday I got a great deal.
https://www.amazon.com/GOOLOO-GP4000...2-8997e41410bb
Old 11-28-2022, 01:00 PM
65madgoat's Avatar
I have this NOCO one and cranks the biggest cube motors with ease (just $164 on Amazon):
https://www.batteryjunction.com/noco-gbx75.html
And of course they make even more powerful ones too....
Old 11-28-2022, 03:26 PM
Longs's Avatar
Longs Longs is offline
I also have the GB40, have only used it once on a 3.5L Chrysler, did the job no problem.
The premise of many of these types of jump starter is that the car wants to start, other than the battery being dead. That's not the same as needing to crank a V8 for 20 or 30 seconds when it's flooded and the battery's getting weak from all of the cranking.
The Following 2 Users Say Thank You to Longs For This Useful Post:
Old 11-28-2022, 07:55 PM
Itsa Wintertime for most of YOUR readers. Most lithium batteries go dead at 32F, and some cannot revive, or revive to < 50% ability.
Some AUTOMOTIVE lithium chemistry claim to stay alive to -4F so be sure to get that chemistry. So those are viable, if you feel lucky. Admittedly, I am not chemically-aware of how the Li-ion battery technology solved the "dead-from-cold" trait. Wondering if the "boom or burst-in-flames" factors were also improved. Li-iron-phosphate is out, so Li-carbon might do it, but are there Side-effects?
My Lead-Acid resides in the trunk, can take that cold, and NOT go dead.
Old 11-29-2022, 03:11 AM
lust4speed's Avatar
The ones I have tried will not work with a 100% dead battery because the computer chip won't close the circuit unless it sees enough residual voltage. I've also had the new cells time out after a few seconds and shut off before the car battery can support the engine.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
The Following User Says Thank You to lust4speed For This Useful Post:
Old 11-29-2022, 06:49 AM
dataway's Avatar
dataway dataway is offline
I've got a lithium-iron battery in my motorcycle that is rated for snowmobiles, so they will work in the cold. You do sometimes have to key them on for ten seconds or so with the headlight on to let them warm internally.
Guess it all depends on your needs, heck, put the jump starter inside your jacket for a few minutes to warm it up. I keep mine in the house so temps are not a problem. If on the road, keep it behind the seat in the truck so it's not -10.
Six of one, half dozen of the other, 50 lb battery is not the most convenient thing either.
Old 11-29-2022, 10:15 AM
Longs's Avatar
The NOVO GB40 I have does have an override capability where you can bypass the built-in the safety protocols if the battery's voltage is too low.
I haven't needed to try that, and it comes with the usual caveats and disclaimers about hooking it up incorrectly, etc. that you'd expect, for liability purposes.
Old 11-29-2022, 01:29 PM
dataway's Avatar
I've got the Noco GB40 also, love it so far.
