Old 11-30-2022, 11:37 AM
imposter's Avatar
imposter imposter is offline
Default 66 stock front brake drums
is it ok to separate the drum from the hub, and leave it installed like that, or does it need to be that way, does it affect the balance
Old 12-02-2022, 04:26 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
Yes it’s ok. In fact, when you buy new front drums you have to take the hub out of the old drum and use it with the new drum. New drums used to come with retainer clips to go over the wheel studs to hold the drum on the hub.
[SIGPIC][/SIGPIC
The Following User Says Thank You to 6T5 Cat For This Useful Post:
Old 07-21-2023, 07:54 PM
imposter's Avatar
yes thank you, i took care of the original drum to new drum issue, i left it separated, if thats ok, so next please excuse the dumb question, i have access to a set of 15" 8 lug wheels and drums, is it possible to use rear 8 lug drums on the front if the hub is separated as well
Old 07-22-2023, 10:26 PM
jamesq's Avatar
jamesq jamesq is offline
I think 8-lug front drums include the hub, but I don't know if we are talking about the same thing.
James Q
James Quayhagen
Old 07-24-2023, 10:11 AM
imposter's Avatar
the front bolt on to the spindle wondering if there the same front and back
Old 07-24-2023, 04:46 PM
jamesq's Avatar
No, rears bolt to the axle via the five lug nuts.
James Q
James Quayhagen
