Old 12-01-2022, 08:48 PM
JSuchma JSuchma is offline
Default 1969 GTO RALLY CLOCK
I got this clock in a parts lot so I do not know what the actual condition is internally, or if it even works. Externally it is in very good condition. $100 shipping in the cont.us.
ID:	602836   Click image for larger version
ID:	602837   Click image for larger version
Old 05-03-2023, 09:56 AM
$80.00 shipped
Old 05-03-2023, 10:46 AM
1969GiPper 1969GiPper is offline
To find out if it works connect a fused jumper wire from the electrical terminal on the back of the clock to the positive terminal on a 12 volt battery. Then connect a jumper wire from the metal clock housing to the negative terminal on the same 12 volt battery. If the clock works you should hear a single click type sound. That click is the clock winding itself. Following the click you will hear the clock ticking. If you don’t hear the click followed by the ticking the clock doesn’t work.
Old 05-03-2023, 11:44 PM
Thanks for the info. I'll look into testing it.
