Old 12-04-2022, 07:25 PM
68tpls400 68tpls400 is offline
Default 74 fender vents mesh
On my (mostly) original paint '74 t/a, we noticed that the mesh behind the fender vents is black. The rest of the fender vent and surrounding area is body color. (Buccaneer red)
Is this how they came from the factory?
All my other cars are black, so I've never noticed this before. Almost looks like they added the mesh AFTER painting, meaning I do not see any obvious masked areas.
Old 12-04-2022, 08:28 PM
Yes, they are a black,probably more flattish black.
Old 12-04-2022, 09:45 PM
Trevor78 Trevor78 is offline
Also true, the pre-blackened mesh was added after painting. The production line had painted and completed vents lined up ready to go to suit car being assembled, of which most was also already painted.
Here's photos of a NOS fender vent sold as a replacement spare part, albeit in light grey primer instead of finished paint including inside the vent housing. In this scenario they'd need to mask up the mesh, or respray, or simply ignore was fairly common too. Also note that the rear doesn't have any primer or overspray so that the mesh goo has a good fix onto the fender material. It also shows that the original mounting studs were also glued into place with a resin looking epoxy, not a tight threaded fit that can damage and distort over time.
There's a possibility that the vents could also have used an insert template for shops and dealers doing touch-ups and resprays a lot. Formula Hood vents had these on replacements as did something else that's escaped my memory at present.
NOS GM 70-81 Trans Am RH side fender extractor vent 480796 (2) by Ben, on Flickr
NOS GM 70-81 Trans Am RH side fender extractor vent 480796 (3) by Ben, on Flickr
Old 12-04-2022, 10:36 PM
Yes, they are a flat black.
Thanks!
Old 12-04-2022, 10:37 PM
Yes, looks just like the ones on my car.
Thanks for the info and pictures.
Old 12-17-2022, 04:36 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
'74 was the last year for the black mesh. After that, it was all painted body color. No doubt, this was done to save money. I like the contrast.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 12-17-2022, 07:50 PM
That would be why I've never noticed on my '76 cars before.
Old 12-18-2022, 08:58 PM
JUDGE3 JUDGE3 is offline
mines a 72 but i'm going to paint the whole thing body color. to much trouble to mask off for black and i prefer the whole thing body color anyway.
