Old 12-12-2022, 10:12 PM
64speed's Avatar
64speed 64speed is offline
Default Power windows
I have the Nu Relics power window kit in my car and I have a question. The power wire coming of the harness is about 8 gauge because it uses modern (2002/2017 Silverado) window motors. I have no where to hook a wire that gauge so I hooked it directly to be battery which in turn means they have power all the time. I am ok with this if this is the way it has to be but does anyone know a better way?
Old 12-12-2022, 10:58 PM
firechicken's Avatar
firechicken firechicken is offline
Install the power wire to a relay that is energized by the ignition switch.
Old 12-12-2022, 11:05 PM
64speed's Avatar
I have an add a circuit kit from painless but the wires coming out are like 16 gauge
Old 12-12-2022, 11:13 PM
242177P's Avatar
242177P 242177P is offline
Which is why he said "... to a relay that is energized by ..." HTH.
Old 12-13-2022, 12:58 AM
64speed's Avatar
It is a relay,,..does it not matter the gauge after the relay.
Old 12-13-2022, 06:17 AM
Yes it matters. The relay needs to meet or exceed the current draw of whatever it is to feed. Wire size is a good indicator but actual amperage would be better to know.
The Following User Says Thank You to firechicken For This Useful Post:
Old 12-13-2022, 08:36 AM
Trevor78 Trevor78 is offline
That's how a power window knows when to stop going up or down.
Old 12-13-2022, 11:28 AM
GoGoat GoGoat is offline
Make sure you get a continuous duty relay if you go that route.
Old 12-14-2022, 05:58 PM
Tim Corcoran's Avatar
Run wire from battery to relay, then from relay to the window motors. Run the trigger wire from the ignition switch to the relay. The trigger wire can be any size as it doesn't carry much current a 14 or 16 gauge wire would be fine. Whenever the key is on you will have power to the window motors, so anytime you're driving the relay will be energized that is why you need a continuous duty relay. The relay will come with proper wiring instructions.
Tim Corcoran
