Old 01-25-2023, 07:48 PM
64speed's Avatar
64speed 64speed is offline
Default Bellhousing Bolts
The Allen head bolts that came with the QuickTime bellhousing are awful to get at in two places with a wrench or socket. I cut an Allen wrench down to make it easier but it still sucks. Is anyone using the ARP 129-0901 bolts on a thicker than stock bellhousing? Are they long enough?
Old 01-25-2023, 08:05 PM
grivera's Avatar
grivera grivera is offline
Not sure if this helps but you can get individual ARP bolts from Allen’s Fasteners in almost any configuration. https://www.allensfasteners.com/sear...rchParamCat=61
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 01-25-2023, 09:39 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Another thing to try is using the cut off portion of your Allen wrench and silicone it into a swivel socket, whatever size they are that fits the allen wrench.
Using a long extension it is sometimes easier. Not saying this will work for your application, but I have used this on my 64. Might have to drop the rear of
trans down little as well.
64 Lemans hardtop
4spd, buckets
Old 01-25-2023, 10:47 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Would ball-end allen wrenches help?
Old 01-25-2023, 11:53 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
Use conventional 6 point bolts for the top....use a rachet wrench
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
