Old 02-05-2023, 10:15 AM
dv657172 dv657172 is offline
Default Oil Pan Upgrade?
Have a 65 GTO for drag racing (no street activity). Pulling engine out to replace leaking rear main seal.
Engine is 68 400 with stock oil pan, car has only seen a few runs so far with best of 12.16 at 108. Hope to get car into 11s and maybe 10s someday.
While engine is out, should I upgrade oil pan. If so recommendations/advice?
Any other ideas of things to do/improve while engine is out of car that wont break the bank?
The Following User Says Thank You to dv657172 For This Useful Post:
Old 02-05-2023, 10:30 AM
78w72 78w72 is offline
if the stock pan isnt baffled, at a minimum i would find a stock mid to late 70's pan that is baffled.
a true upgrade pan would be an aftermarket like canton or other brands, i use a milodon 7qt pan on my 467 engine that is very nice but a little pricey.
Old 02-05-2023, 05:22 PM
Gary H's Avatar
Gary H Gary H is offline
I'd go with a Canton, Moroso, or Milodon pan. Make sure you get the correct corresponding oil pump pick up. The stock pan is marginal for any high-performance use. Just not enough capacity IMO.
Old 02-05-2023, 05:34 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
I am in the middle of pulling my 541 to change the oil pan....When I last freshened this up a few years ago, I had to settle for a Moroso cause the Canton replacement for my bent up Canton was months away. The Moroso caused lots of grief. Not enough baffling and the oil will all slosh forward at the big end when I lift....Oil pressure to the basement as the pick up and pump were exposed. The Canton in my view has way better baffles.
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 02-06-2023, 06:00 AM
Dragncar Dragncar is online now
I ran a stock oil pan into the 10s for years.
Good luck getting a Canton Maxi pan. Called them up and they have not made one in over 10 years, do not even have the drawings for it and had the nerve to ask me if I had pictures of one they could copy one. AND it was a crazy wait time., 1200 $ Joke.
Bought a Steffs.
Old 02-06-2023, 09:30 AM
Don 79 TA Don 79 TA is offline
maybe if you have someone competent enough nearby, they could extend the bottom of the stock pan???? make it like a deep sump or wider sump area?
just a thought in the event of not being able to find another pan
then use a windage tray or crank scrapper? but i've heard not necessary if using a vaccum pump????? anyone have any knowledge/experience regarding that?
i used a canton in the past (stock replacement one) and i can tell you, compared to an original GM pan it certainly was sturdy
the stock replacement one on my current engine, sorta flimsy if you get my point. i think it was a dorman replacement one
if i ever pull the engine i want to go with a canton or at least something else sturdier with a little more capacity. but since it's sealed and leaks, i am not bothering lol
Old 02-06-2023, 11:32 AM
Thank you all for the thoughts and comments. Sounds like its time to try and find a Canton pan. Seen some on Butler website. Hopefully not too hard to get nowadays.
Old 02-06-2023, 03:00 PM
For what you are doing this pan is hard to beat. And its available.
Nightmare Performance,s pan is 749 $ but comes with everything you need and is kinda trick. It has 3 trap doors and baffles to keep oil around the pickup and to keep oil from climbing the back wall on launch.
It comes with a directional windage screen built into the pan. You can use your stock dipstick and even comes with a factory internal dipstick tube.
And oil pump with their machined 1/4: bottom plate and oversized pickup is included.
Its hard to beat and the owner is a real deal Pontiac die hard. Great to deal with.
http://nitemareperformance.com/roadracepan.html
Name:	Screenshot 2023-02-06 at 10-46-16 Nitemare custom oil pan pump and pickup to fit '64-'72 GTOs an.jpg
Old 02-07-2023, 11:01 AM
Thanks Dragncar! Not sure that one is in the budget given a few other car expenses this spring but will definitely give it some thought. It sounds like it definitely would do the job down the road for sure
Old 02-07-2023, 05:49 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
I have a Moroso 20490 9-3/4” deep oil pan I was going to use on my Firebird Build but went with a Stefs. This is used and has no trap doors but does have the oil containment plate in the sump. I have a good High Pressure pump and pickup that goes with it. Pickup is brazed to the pump. $250 plus shipping for it it if you are interested. Message me and we can work our shipping from Central Missouri.
Old 02-11-2023, 12:30 PM
Tom Vaught's Avatar
Boost Engineer
I have seen posts like this for years, BUT NO ONE seems to recommend a 1/2" wide angled steel "deflector" on the back wall to turn the oil slamming into that wall on hard launches.
Easy to do with the pan off, Oil Pump will clear the "deflector" in installed about 1/2 way
up the back wall of the pan.
Also some very good Oil Pan info/Pictures in this "Pontiac Jim" link:
https://www.gtoforum.com/threads/pon...e-tech.137776/
Tom V.
The Following 4 Users Say Thank You to Tom Vaught For This Useful Post:
Old 02-11-2023, 02:43 PM
mgarblik mgarblik is offline
That steel oil pan from Nightmare looks pretty pricey until you read through the description. It is more less an oil system. It includes a nice oil pump, pickup and dipstick tube. That added stuff is probably worth $150-200.00 . So not terrible for the pan.
Old 02-12-2023, 09:31 AM
gman005's Avatar
gman005 gman005 is offline
I run a Nightmare oil pan.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 02-12-2023, 06:00 PM
Tom V.
Mt Steffs pan has a strip on the back wall for keeping oil down on launches.
The Nightmare pan does have some metal back there that could help keep some oil down at launch. If they sold a pan like this but with the passenger side kickout like the Canton pan that you can not get anymore they would sell a lot of them. Trap doors, built in windage screen, full baffle and a big kickout to give the oil coming off a scrapper somewhere to go they would sell. If they could design a scrapper to go with it all and still use a factory style dipstick all the better.
Name:	Screenshot 2023-02-12 at 13-56-05 inside of GTO pan white.gif (GIF Image 800 × 540 pixels).png
The Following User Says Thank You to Dragncar For This Useful Post:
Old 02-21-2023, 06:20 PM
ErikW's Avatar
ErikW ErikW is offline
The Canton 15-452 pan is more than adequate for your setup. The bolt in baffle in the pan also has the back wall deflector that Tom talks about.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 02-22-2023, 08:12 AM
Thanks again for everyones thoughts, will likely be going with a Canton pan 15-400 or 15-452
My current pump is practically brand new and only has 13 runs on it. Any reason why I cant use that with a longer pickup in a Canton pan?
Old 02-22-2023, 08:21 AM
Tom Vaught's Avatar
Boost Engineer
Not Really if it is a 60 psi pump. It should be.
Tom V.
Old 02-22-2023, 09:32 AM
Probably is, wont know until I get pan off and take it out.
Any recommendations on the pump?
Old 02-22-2023, 03:24 PM
Tom Vaught's Avatar
Boost Engineer
Melling has always been my oil pump of choice.
Others out there are probably as good.
Since your engine is drag race only and you are currently running 12s
you should be fine with the 400 engine and the 60 psi oil pump for a while.
3.75 stroke does not have the same forces on it as a 455+ or larger stroker.
Same deal with straight shot oiling crankshafts. Nice to have but you are not there
currently.
Continue to get track time when you can. The guy behind the wheel is worth several
tenths.
Tom V.
Old 02-22-2023, 08:01 PM
Thanks Tom for the advice and encouragement.
DV
