Old 02-21-2023, 08:45 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Default Older 400 in 1972 A body
I picked up a nice 69 400 w/62 heads from good guy here on the boards. If I wanted to run the engine in my 72 lemans, can it be done? I believe the engine mounts are different. What would I need to do to make it happen? Thanks
Old 02-21-2023, 09:09 PM
tooski tooski is offline
OK, I'll start by saying Butler has adapter brackets.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
The Following User Says Thank You to tooski For This Useful Post:
Old 02-21-2023, 09:19 PM
1968GTO421's Avatar
Butler is great. Done Pontiacs for years and have really good advice.
Butler Performance Inc.
2786 Hwy 43 North
Lawrenceburg, TN 38464
Contact
Tel: (866)762-7527
Fax: (931)231-8018
GTOAA--https://www.gtoaa.org/
Old 02-21-2023, 10:35 PM
It's a direct bolt in as long as the '72 LeMans came with a 350 Pontiac or 400 Pontiac.
Only time, you would have issues with the '69 & earlier block, is if the LeMans was an original 6 cyl car, or the '72 LeMans was factory optioned with a 455 D port or 455 HO engine.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 02-22-2023, 07:17 AM
25stevem's Avatar
25stevem 25stevem is offline
It's 100% drop in as would be any 421, 428 or even any 455 since they where cast with all of the 5 needed bolt holes on each side of the block to go into the 70 and up F body cars.
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 02-23-2023, 09:12 AM
Skidmark's Avatar
That's good news. Thanks.
