Old 03-01-2023, 06:40 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Question on vacuum advance can
Guys. Does anyone know the cut in specs on a Delco 1973624.
I know it provides 20 degrees of advance, just want to know how much
Vacuum to do so.
Thanks.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 03-01-2023, 08:00 PM
25stevem's Avatar
25stevem 25stevem is offline
Do you have a buddy with a mity vac?
I do stuff for reasons.
Old 03-01-2023, 08:20 PM
Default mity vac
I have a new one on order now!!!!
thanks
Gerry
Old 03-01-2023, 10:16 PM
Shiny Shiny is offline
Take this all with a grain of salt and for sure, verify what you have as you are planning to do with the Mityvac...
I found a GM-to-Delco cross-reference online here:
Link to Delco Cross Reference
It says your 1973624 is a Delco D1369A
I then found a reference here (credibility?) that says the NAPA/Echlin equivalent to a Delco D1369A is VC1859.
Finally, in the Lars Grimsrud "Distributor Vacuum Advance Control units
Specs and facts for GM Distributors" doc that is widely quoted online, the VC 1859 specs are listed as:
Starts 3-6" Hg
Max of 10 degrees (20 crank as you state) @ 9-12" Hg
If you have an original Delco part, it may well match. If aftermarket, I recently found a Std Motors advance unit was close on both the start and the max specs, but there was no mechanical limit at the max, so the advance continued beyond the max-rated vacuum level.
Good luck!
Mike
Old 03-02-2023, 07:38 AM
Default thanks
Thanks Shiny,
cleaning out old stash of used parts, & I came across this piece.
Curious to see if adding more vacuum advance would have any benefits.
The Vac Can in my HEI currently adds 10 and works well. Did not want to modify it,
just wanted to try another with lower start point.
Always tinkering!!
Gerry
Old 03-02-2023, 11:27 AM
Formulajones's Avatar
Originally Posted by 68 Firebird View Post
Thanks Shiny,
Always tinkering!!
Gerry
If your distributor is dialed in as it should be with a decent amount of mechanical advance that works with your engine (34 degrees for example) then adding another 20 degrees of vacuum advance on top of that is generally not a good idea, and most engines will not like it.
The additional 10 degrees you have now with your current vacuum advance is about where you would need to be for best results that generally works well on most any engine.
However, if you need a lower starting point, and if this new can offers that, you can simply limit it's ability to add 20 degrees by welding the slot. You would want to limit it's travel to only give an additional 10-12 degrees of advance at the crank, like your current can, and then enjoy it's earlier starting point to see if that offers any benefits for you.
That would be the proper way of doing it so you don't risk engine damage.
https://youtu.be/XqEydRRRwqE
