Old 03-03-2023, 07:45 AM
necdb3's Avatar
necdb3 necdb3 is offline
Default engine paint
What engine paint are you guys using for a 66?
Old 03-03-2023, 08:16 AM
propuckstopper propuckstopper is offline
Bill Hirsch. It is awesome.
Old 03-03-2023, 09:25 AM
tempest1964's Avatar
There was also a recent thread in 'Street' section about paint. The Seymour brand got good reviews for the '59-'66 engine color.
https://forums.maxperformanceinc.com...=seymour+paint
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 03-03-2023, 09:42 AM
necdb3's Avatar
Thanks for the replies. Just wondering if anyone has found a paint that doesn't burn off the exhaust ports of the heads. I drive all my cars and it's frustrating when that burns off. I believe 66-70 are the same color, correct?
Old 03-03-2023, 10:06 AM
Nope. ‘59-66 is like a Robin egg blue. ‘67-70 has metallic in it.
Old 03-03-2023, 10:36 AM
Stuart's Avatar
Stuart Stuart is offline
This page has information on the different colors used over the years, along with suitable paints for each color. http://www.pontiacpower.org/enginecolor.htm Note that Plastic-Cote paint has been discontinued.
As for the paint burning off, I don't think there's any solution that will be 100%. I've had some luck spraying the exhaust port parts of the heads with alight coat of high temp silver paint first before applying the Pontiac blue, but I think it only slows the inevitable.
The Following User Says Thank You to Stuart For This Useful Post:
Old 03-03-2023, 11:18 AM
pfilean's Avatar
pfilean pfilean is offline
Stuart
I have seen that one before. Never remember where to find it if I want it. Maybe you should put it on a sticky.
Old 03-03-2023, 12:12 PM
Stuart's Avatar
It's easy to find, just do a search on 'pontiac engine paint' and it pops right up.
Old 03-03-2023, 01:01 PM
Kenth's Avatar
Kenth Kenth is offline
Wrong! 1959-65 Light Blue, 1966-70 Silver Blue Metallic.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-03-2023, 01:53 PM
necdb3's Avatar
There seems to be conflicting opinion on what the color of 66 engines were. Stuart, your listing shows 66-70 as the same color, is that correct? Hoping for an original car owner to settle this. I would hate to paint it the wrong color.
If the Hirsch paints are the longest lasting, I'll use them, the only issue I saw with their paint is, it says not to run the engine for 2 weeks after painting or it could wrinkle.
Old 03-03-2023, 03:41 PM
Stuart's Avatar
I'm not an authority on colors - I really only know the 1965 and earlier engines - but that page with the colors has been around a long time and my understanding is it's considered to be the authority on the subject.
Old 03-03-2023, 04:01 PM
necdb3's Avatar
I agree, however, I just purchased a 66 2+2 convertible and this is my first dive into any Pontiacs pre 69 as far as me owning them. I normally use that very site for my other Pontiacs and trust it. My thought is that the site is correct, just want to make sure.
Old 03-03-2023, 05:28 PM
Thanks for the correction Kenth
Old 03-03-2023, 05:53 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Agree that Bill Hirsch engine paints are great. Unfortunately if you decide to go with the Pontiac metallic Blue they have been unable to get the quarts or aerosol for quite some time.
Old 03-13-2023, 07:49 AM
necdb3's Avatar
Update: Hirsch paints said it would probably be 2 months before the get engine paints. The 66-70 color he said would likely come in quarts first and then they have it put in spray cans. 2 months for quarts, obviously longer if you desire spray cans.
The Following User Says Thank You to necdb3 For This Useful Post:
Old 03-13-2023, 10:44 AM
61-63 61-63 is offline
Just take a valve cover or whatever of the color you need to an ACE hardware and have them scan it and mix up a quart of oil based paint in that color. Of course you need an air compressor, reducer (mineral spirits or turpentine), and a paint gun to spray it. But I have found that paint to be as good as any off the shelf spray bomb. None of them will survive the areas where the paint burns off.
Old 06-04-2023, 07:22 PM
necdb3's Avatar
Just ordered some spray paint for 66-71 engines. It's now in stock for anyone interested from Hirsch Paints.
Old 06-05-2023, 08:42 AM
mgarblik mgarblik is offline
Little side note about exhaust port "burnoff" I recently painted 2 Pontiac engines with aluminum heads. One is an Iron block and Edelbrock aluminum heads. The other is an aluminum block and Kauffman highports. The iron block is painted with DE1610 Dupli Color rattle cans. The all aluminum one with DE 1616 Duplicolor Rattle cans. Both have been through multiple dyno sessions and the one with DE 1610 has about 700 street miles on it. Not a hint of discoloration or burn off on the exhaust ports yet on either engine. My conclusion is the aluminum exhaust ports are not reaching the critical temperature to ruin the paint like the iron heads do. Typically, iron heads have the paint burning to white or flaking off after 2-3 hours of operation. Your results may vary.
Old 06-05-2023, 10:46 AM
misterp266's Avatar
Mike, did you do anything special to the aluminum heads before spraying them with the Duplicolor? I was considering using Alodine on mine before painting. I don’t usually paint aluminum parts but I want my heads painted.
" Darksiders Rule "
Old 06-05-2023, 04:06 PM
I didn't do anything other than make sure the surface was really clean. Painting is really not my thing. Clean and dry and shook the heck out of the rattle can. I also wanted the painted look on the heads. I did not paint the bathtub intake on one engine or the Northwind dominator intake on the other one.
