Old 03-04-2023, 06:57 PM
necdb3's Avatar
necdb3 necdb3 is offline
Default 66 intake and carb
Looking for a 1966 421 intake and carter carburetor. Should be a 4037s carb. Hoping someone has a set up they removed to install a tripower. Looking for 7/65 -11/65 date code if possible. PM if you have one. Thanks, Dave
Old 03-04-2023, 07:36 PM
tom s tom s is offline
I have a intake,will look at the date.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 03-04-2023, 09:08 PM
jamesq's Avatar
jamesq jamesq is offline
Are there any differences between the 389 and 421 4bbl intakes?
I have a distant memory that they used the same casting numbers.
James Q
James Quayhagen
Old 03-04-2023, 09:54 PM
All the same.
Even the 326 HO and 350 HO used the same 4-barrel intakes as the bigger engines. Same goes for standard exhaust manifolds.
Old 03-16-2023, 08:08 PM
necdb3's Avatar
Intake found, Thank Hank and PY!
Still need a 4037s carter carb though.
