Old 03-06-2023, 11:10 AM
TA-71 TA-71 is offline
Default 70 Trans Am strong fuel odor after driving.
I have a new to me 70 Trans Am, RA3 4-speed. Trying to sort out some issues. First up is a VERY strong fuel odor after driving. Not as noticeable under the hood, seems to be from the rear of the car, gas tank area. I have checked the rubber lines under the passenger seat, they seem fine, no leaks.
Any suggestions before I drop the tank to check all the lines?
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
Old 03-06-2023, 11:19 AM
Formulabruce's Avatar
This have EEC? Seen those plastic "boxes" leak with modern fuel, and its warm enough there to vaporize it instantly.
Old 03-06-2023, 11:43 AM
This was a California car, so yes it has the EEC. The canister under the hood has been disconnected, I guess I will need to figure this out as well.
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-06-2023, 01:54 PM
mlewisariz mlewisariz is offline
All 5 hose connections can be seen and serviced without dropping the tank. Two are from the sending unit which is hard piped from the top to the two longer hoses on the upper front passenger side. Three other connections are short pieces connecting to chassis mounted hard lines. Best to have a lift for easier access.
1970 Trans Am RAIII 4/spd Blue/Blue Van Nuys built
1977 Can AM 400ci Sunroof car
1973 Grand Prix 400 A/T (Parting out)
The Following 2 Users Say Thank You to mlewisariz For This Useful Post:
Old 03-06-2023, 04:16 PM
The EEC is ABOVE the factory crossflow Muffler, and is the Piece I am talking about. It is 1970 Cailf car only. Also used a canister up front, but smell is out back.
I have a set up off a 1970 Formula if you need pics.
These were FACTORY installed in California built AND Norwood built Firebirds Sold in California.
ID:	608451   Click image for larger version
Old 03-06-2023, 05:09 PM
Can this be bypassed? Or is it something that is needed?
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-06-2023, 05:25 PM
Formulajones's Avatar
That's probably the start of the issue. Sounds like it's been monkeyed with. Not surprising to see that, as most people really don't understand how that system functions to vent the tank and quickly start removing parts and disconnecting hoses.
With it all hooked up and working properly, you won't have any gas smell.
My 70 Formula built and sold in California has all the stuff Formulabruce mentioned, hooked up and working.
Me personally, I'd go through the whole system checking lines and get everything hooked back up as it should be and go from there.
https://youtu.be/XqEydRRRwqE
The Following 2 Users Say Thank You to Formulajones For This Useful Post:
Old 03-06-2023, 05:37 PM
Does anyone know if a replacement canister that mounts above the tank, is it available today? or something that would function in its place?
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-06-2023, 05:47 PM
If you're referring to the piece that Formulabruce pictured, I think they call that the separator assembly.
I don't recall seeing those sold new anywhere but I would think they would be. You can buy the charcoal cannisters new so I would think the separator would be available somewhere.
Old 03-06-2023, 05:48 PM
The EEC set up ( separator) in my pics? No, not available aftermarket because of the '75 and older rule in calif? I think that's the cut off for must have all the emission.
I would sell what I have in the pic if needed and it has never seen any alcohol fuel. Obviously new high heat fuel lines are required. You should be able to get it going without too much trouble. Does your car have the EEC unit and the front canister still in the car?
Old 03-06-2023, 07:37 PM
Yes it still has the EEC and the front canister, so I hope I can get this reconnected and working without too many issues.
Anyone have a diagram on how this all hooks up?
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-07-2023, 04:40 PM
Looking for a diagram on how the EEC system is laid out.
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-08-2023, 03:20 AM
I have that but cant get to it for a few days. May be in the 70 Firebird suplement manual.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 03-10-2023, 11:38 AM
Can someone tell me the correct size fuel line hose and the hose size for the vapor lines?
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-12-2023, 12:27 PM
giles's Avatar
giles giles is offline
This “vapor separator” is intended to keep liquid gasoline from making its way to the canister. Liquid fuel can deactivate the charcoal. Unfortunately the 70 only California-only separator was replaced by the standpipe set up behind the rear seat on all 71 and later 2nd gens. I suspect once you connect everything your fuel smell issue will be solved.
Old 03-12-2023, 01:22 PM
Formulas Formulas is offline
Do you have a vented fuel cap ?
If your not at the table you're on the menu
Old 03-12-2023, 01:35 PM
Send me an email and I can send you some pics from assembly manual.
johnta1@wallaceracing.com
Old 03-13-2023, 09:31 AM
No it is non-vented
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-13-2023, 09:34 AM
Email sent
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 03-13-2023, 10:59 AM
My emails were getting bounced back.
Try this link:
1970 Vapor Separator
