71 In Dash Tach
I will be replacing my clock with a tach. I have the tach wire harness. Question is will the power wire to the clock serve the purpose for the tach, or is another source preferred. Thanks
You need to run a wire from the coil to the tach.
original 69-71 tach or reproduction?
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express 2024 Cadillac LYRIQ |
Power wire to the clock is "always on". Power wire to the tach normally would not be. That said, the amount of current the tach pulls from the wire wouldn't be much.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
The Following User Says Thank You to Bill Hanlon For This Useful Post: | ||
Thanks. This is one of the new metal after markets from The Parts Place. Looks pretty good. I have the tach harness that goes to the coil. Ill look for a switch on hot wire for power. Waiting on the Rally conversion to replace the idiot lights at the same time. Thanks again.
