Old 03-11-2023, 04:34 PM
grivera's Avatar
grivera grivera is online now
Default Air Cleaner Style and Performance Opinion
So my 64 LeMans has dual Edelbrock quads with an Edelbrock intake and due to the spacing, air filter styles are limited. PO installed a set of 6.5” boat spark suppressors which look really cool but the suppressor height is 1.5” and of course there barely any air filtration with these.
I tried the Edelbrock dual quad oval air cleaner but it has a 2.5” pink, oiled filter element and it clashed with the look so I painted it black and still looks bad. The latest is a set of 6.375” chrome air cleaners with 2.5” elements.
So what are your thoughts on the look of these? I do like the look of the spark suppressors but not sure if the lack of filtration will cause issues on a car that will see <3k miles a year. Do the spark suppressors outflow regular air filters? If the lack of filtration is a major factor I will be keeping the chrome air cleaners on there. Any other option I’m overlooking?
ID:	608698   Click image for larger version
ID:	608699   Click image for larger version
ID:	608700   Click image for larger version
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 03-11-2023, 04:40 PM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
I like the look of the chrome ones the best.
The Following User Says Thank You to 400 Lemans For This Useful Post:
Old 03-11-2023, 05:15 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is online now
Default chrome
yes the chrome style units look great
gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
Old 03-11-2023, 06:38 PM
25stevem's Avatar
25stevem 25stevem is offline
Any air filter assemblys flow rate is highly dependent on the base it’s sitting on in terms of height above the Venturi and the radius leading to the top of the carb.
You can have a great flowing filter , but the base can murder your hp numbers if your air filter area is already on the edge of not cutting it.
Also note that air filter assembly’s that have a added filter in the lid are the worst thing you can have as test have shown.
ID:	608707   Click image for larger version
ID:	608708   Click image for larger version
ID:	608709   Click image for larger version
ID:	608710   Click image for larger version
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 03-11-2023, 07:18 PM
Steve C. Steve C. is offline
Stated- "Also note that air filter assembly’s that have a added filter in the lid are the worst thing you can have as test have shown."
THAT IS NOT NECESSARLY CORRECT.
Much depends on the carb used during testing. With independent testing over the years it is suggested a carburetor with a smooth inlet contour for the airflow works well with it, like the Holley "HP" series.
A carb design WITHOUT a smooth contour, example one with a choke tower and a Q-jet carb design, can affect the testing results. The Holley 'HP' series carb with it's smooth contour is a completely different ballgame.
It reduces intake turbulence.
Onward thru the fog.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 03-11-2023, 08:15 PM
geeteeohguy's Avatar
The dual chrome and paper ones look the best. My bet is the K&N style one that looks ugly will actually perform the best.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 03-11-2023, 08:58 PM
tom s tom s is offline
Its a street car!The best one will be the one he likes looking at the best!KISS!Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 03-11-2023, 09:56 PM
Why don't you have one made? Combine good looks and practicality. Something like the Mopar Hemi air cleaner has a large diameter.
Old 03-11-2023, 10:13 PM
Check the center to center and see if a big 409 AC will fit if you want something like that.Tom
Old 03-11-2023, 10:27 PM
I would run the reproduction 421 SD air cleaners.
Even if I had to swap to an Offenhauser intake to use them.
Pretty sure the Edelbrock intake puts the carbs too close together to.use them. Swapping to the Offy intake will net you a power increase so win win.
ID:	608722   Click image for larger version
ID:	608723   Click image for larger version
Old 03-11-2023, 10:43 PM
grivera's Avatar
Good points- I am too cheap for a custom option!
Will Rivera
Old 03-11-2023, 11:24 PM
Bart,his carb tops are too big for the corvette-SD A/Cs.Tom
Old 03-11-2023, 11:30 PM
grivera's Avatar
Someday I may get an Offy - not sure why Edelbrock puts the carbs so close together
Will Rivera
Old 03-12-2023, 06:36 AM
25stevem's Avatar
Edelbrock put the carbs closer together to have longer runners and build a more usable average torque band.
The Edelbrock duel quad is stated as having a power band of 1500 to 6500, where as the high rise Offy 360 intake is stated as having a power band of ( and I quote) 1800 to 8800!
This high of a power band of course is very much CID dependent.
Old 03-12-2023, 08:21 AM
grivera's Avatar
Aside from looks and inability to filter out particulate, are spark suppressors a contender when it comes to flow?
Will Rivera
Old 03-12-2023, 10:22 AM
Cliff R's Avatar
Cliff R Cliff R is offline
As mentioned air cleaner assemblies can have a MAJOR impact on power. I've done a good bit of testing in that area and this is what I found.
Drop base air cleaners are horrible if/when they move the lid too close to the carburetor. I like to see a minimum of 3" from the air cleaner gasket to the bottom of the lid. You can get away with a little less than that if the air cleaner lids and bases are radiused to help direct flow into the carburetor.
Filter lids, like the K & N Xtreme lid are worse than running a solid lid with a nice contour to it. I've also experienced stumble/hesitation/bog going quickly to full throttle testing the Xtreme lid. With the stock Shaker parts no stumble at all, and no stumble at all with nothing above the carb. So not sure why the lid by itself would cause issues but the problem occured both times I tested one on two completely different engine set-ups.
All that testing was done with factory Q-jet carburetors and stock and RPM intakes. You may be able to get away with a little more (air cleaner lid closer to the carb or Xtreme style lid) using a square flange carb like a Holley or AFB.
Not meaning to get off topic but I've ran into issues killing off power and vehicle performance testing things under the carb, like open spacers on divided intakes, and cutting down dividers in dual plane intakes. Dyno and track testing also suggests that at least a 1" well blended open spacer is REQUIRIED on a dual plane intake, and that's with a spriead bore or square flange carburetor, but the power improvements (or differences with or w/o a spacer) were always greater with a spread bore carb vs square flange.........
The Following User Says Thank You to Cliff R For This Useful Post:
Old 03-12-2023, 11:43 AM
Singleton Singleton is offline
Off-topic, but here's an interesting dyno test of 19 different air filter combinations, including the filter lid, stock dual horn, drop bases, velocity stacks, etc. Results at around the 10 minute mark.
https://dai.ly/x693421
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
The Following 3 Users Say Thank You to Singleton For This Useful Post:
Old 04-14-2023, 03:52 PM
Mr6x Mr6x is offline
Show Cars has an open element air cleaner that should fit the Pontiac Edelbrock intake with the 5" carbs. Same carb spacing as the 409. Large filter. Phone: 507-233-1958.
Old 04-14-2023, 09:25 PM
1968GTO421's Avatar
Interesting site, large selectiion of GM air cleaners, pics included if you hover. Thanks.
https://show-cars.com/02-engine-external
GTOAA--https://www.gtoaa.org/
Old 04-14-2023, 10:59 PM
grivera's Avatar
I’ll have to check this out
Will Rivera
