SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 03-12-2023, 11:58 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Default Pontiac Points Distributors
I have two to sell. They will be completely rebuilt and set up exactly for your application. These distributors have been cleaned inspected, housing gently bead blasted and ready to assemble.
They will get all new internals, points, condenser, rotor, vacuum advance and cap. The points, condenser, rotor and cap and all USA made NOS parts. The vacuum advance is new will have a "limiter" to add exactly the desired amount of timing. The advance pin sleeve has been replaced with a stainless steel custom made part.
The shafts have been polished to 1500grit finish and super tight in the bushings.
I'm only listing them before final assembly so I don't have to take them back apart to adjust the timing curve if the new owner wants something different than the stock curve. I can put any amount of advance the new owner wants in the mechanical curve and add any amount desired from the VA as well. I do NOT do super quick "all-in" by 1500 curves as 99 percent of these engines don't need it and it's IMPOSSIBLE to keep some of the curve out at idle speed making tuning difficult if not near impossible.
Once sold the distirbutor will be calibrated exactly for the application and shipped within 2-3 days of the sale date.
Price $225 each.
PM, email, or contact me at the shop for more info, 740-397-2921
[IMG]https://forums.maxperformanceinc.com/forums/attachment.php?
attachmentid=608750&stc=1&d=1678636601[/IMG]
ID:	608749   Click image for larger version
ID:	608750   Click image for larger version
ID:	608751   Click image for larger version
Old 03-13-2023, 04:04 PM
Cliff R's Avatar
One is sold, one left.
Old 03-17-2023, 02:54 PM
Cliff R's Avatar
Second one is sold.
