Old 03-20-2023, 06:10 PM
cnc's Avatar
cnc cnc is offline
Default window lower corner escutcheons
Can someone post a pic of location of these pieces (1973 Firebird) I have them but recall exactly how where they fit…thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 03-21-2023, 09:52 AM
78w72 78w72 is offline
i can get a pic later today if nobody else posts one. there is only 1 small screw that attaches them to the cowl, should see a little hole for it. then at the top, one of the ears tucks under the metal trim piece.
