Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-21-2023, 03:46 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Default Wanted standard bore 400 pistons
Prefer to find a set
Of forged trw Speed pro or 4.120 take outs on rods but will consider all as long as the do not have domes
Also
Want one or two factory 9787610 out of a 70 yd 400 or equivalent
Old 04-01-2023, 12:16 PM
Joe-Touring Joe-Touring is offline
I have a set of 8 from a 67 big car. 2 have busted ring lands. Don’t want much for em
67 LeMans, 326, M20, 3.31 12 Bolt
Old 04-01-2023, 01:10 PM
Any chance you can get the part number off them? Also if you do handle them, can you confirm they are both 5/64 rings? I’m have a set of 68 pistons that have 3/32 second rings and 5/64 tops I had never noticed this in a
Pontiac pistons
Old 04-01-2023, 02:10 PM
P/ns are 9787610. Don’t have the rings, but the pistons measured at 0.0825 top and 0.0785 2nd
Old 04-01-2023, 03:46 PM
Pontiac must have changed in mid 69 I already have a set of rings I want to use thank you for looking
Old 04-01-2023, 07:11 PM
Formulas's Avatar
Formulas Formulas is offline
Soooo will 1 factory 1970 400 piston allow you to reach a goal, i saved 1 from my 400 for some reason, i would have to look for a P/N
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 04-01-2023, 08:45 PM
It is quite
Possible it’s the same thanks for
Looking
Old 04-02-2023, 07:10 PM
Formulas's Avatar
pulled the piston off the wall was hanging on a BME rod
top and second groove are the same size ran a piece of old ring around both grooves no tight spots
appears to be your part number
there is some unexplained handeling gouges on the botton of one skirt just knock down high spots should work fine
also have a good original pin can go with
i never figured on using it again, its yours for shipping if you want it
Old 04-03-2023, 06:54 AM
thank you for looking but i will keep looking for one on a stock rod w normal wear. Much appreciate everyone who has been checking their stashes
Old 04-24-2023, 06:43 PM
KGTO's Avatar
KGTO KGTO is offline
Sooo....I'm supposed to be opening up a 400 that is in a 1970 GTO YS. Very well cared for, compression is still strong on all 8, the engine has never been in to. If we decide to do a full rebuild there would be 8 GM pistons available, unless they can be ringed I guess. Would be in a couple of weeks if this goes as planned...
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
The Following User Says Thank You to KGTO For This Useful Post:
Old 05-01-2023, 09:12 PM
shaker455's Avatar
shaker455 shaker455 is offline
Also
So Jeffrey, Guess what I have for you!
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 05-01-2023, 09:30 PM
shaker455's Avatar
L2359 STD on rods
Old 05-02-2023, 12:02 AM
thepontiacman's Avatar
thepontiacman thepontiacman is online now
L2359 is a 455 piston forged
L2262 is 400 piston forged
Old 05-02-2023, 01:25 AM
77 TRASHCAN's Avatar
Cool
Originally Posted by shaker455 View Post
L2359 STD on rods
Jeff,
I thought you sold those?
Jeff
Shut it off
Shut it off
