Old 03-25-2023, 01:37 PM
beemergary's Avatar
Default THM400 248/148 vs 275/157 results.
After crossing off the new bathtub intake from my bucket list I lost .500 et. Its in my 60ft. -1/8mi. Did some mods to intake and got .250 back but want more. Don't really want to spin my 421sd more. Thanks
Old 03-25-2023, 02:21 PM
25stevem's Avatar
25stevem 25stevem is offline
So do we have to beg and pled for more info about your combo to try and help you out, of give you a few Oz of truth serum?
I do stuff for reasons.
Old 03-25-2023, 05:06 PM
Half-Inch Stud's Avatar
You making more power and less traction?
Old 03-25-2023, 08:26 PM
beemergary's Avatar
No way on traction . Went from consistant 1.54 60ft. to 1.9-2.0. Doesn't get that seat of the pants till past the 1/8 but the shift light will come on just before finish line like before.
Old 03-25-2023, 09:15 PM
ta man ta man is offline
Lets see the timeslips may make more sense.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 03-25-2023, 09:34 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
So are you saying you switched from a 248/148 gear set in your Turbo 400 to a 275/157 gear set and your 60ft went from 1.54 to 1.9-2.0?
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
The Following User Says Thank You to GoatZillaRacing For This Useful Post:
Old 03-25-2023, 09:57 PM
242177P's Avatar
242177P 242177P is offline
I suspect he's considering it, and hoping for input? 60 ft went away after an induction change, even though he's closer now it's still not what it once was.
Old 03-25-2023, 11:37 PM
blueghoast's Avatar
Gary why did you drop the bath tub intake?
Was it because there out ,If so I have one still in the box.
GT
Old 03-26-2023, 08:40 AM
beemergary's Avatar
GT
I replced my sd 359 2x4 with the pre 64 style bathtub.
Old 03-26-2023, 08:45 AM
beemergary's Avatar
Guy's I am looking for results from anyone who has made the change from 248/148 to 275/157 first and second gears. Not really wanting to spin engine at more rpm's at top end.
Old 03-26-2023, 09:06 AM
25stevem's Avatar
What I would do next is get a Tack in the carnthat can play back your runs.
This will allow you to see where in the current rpm band your motor is spending its most time in during a pass.
This greatest amount of time rpm wise is where you should concentrate your efforts on improving.
It sounds like your current combo is more dependent on intake tract air speed then pure top end hp.
Old 03-26-2023, 09:07 AM
25stevem's Avatar
Sorry about this duel post , this site is having issues this morning since I did not do such.
Old 03-26-2023, 04:38 PM
Dragncar Dragncar is offline
If you have a Go Pro maybe you can mount it to record your tach during a run.
You could get a Draggy App if you are a smartphone dude. Or get a G Tech
https://www.gtechpro.com/G-TECH-Pro%20SS
Old 03-26-2023, 09:46 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The results will differ depending on the combination. I ran a 2.75 first gear for many years. The car initially slowed down a tenth or so going to a 2.48 and another tenth going to a 2.20 gear set. My buddy had a bad fast RAIV headed combination and he found better results using a 2.48 and steeper rear gear compared to a 2.75 with slightly less gear. My brothers Firebird ran a bit slower with the 2.75 gear set. I'd think with your deal it will help do what you want, but I wouldn't expect to see much more that a tenth or so improvement. Are you sure the 60 ft can't be helped with some carburetor or plenum work.... That's a big loss you're dealing with.
Go fast, see Elvis!
Old 03-27-2023, 08:18 AM
Stan Weiss's Avatar
What carbs are being run?
Stan
Pontiac Pump Gas List
Old 03-27-2023, 05:51 PM
beemergary's Avatar
Thanks Stan. I did get .250 back from some plenum work but there's probably more to do. That open chamber they used not user friendly with my combo.
Old 03-29-2023, 12:17 PM
racegto65's Avatar
racegto65 racegto65 is offline
I changed the th400 in my firebird to the 2.75 for the same reason (not wanting to increase trap rpm but wanted to lower 60' times). 69 Firebird, 3.90 gear, 389, iron heads, full exhaust and interior. 60's went from mid 1.70's to 1.66/1.68 with no other changes.
