Old 04-12-2023, 12:04 PM
Zappa's 68 Zappa's 68 is offline
Send a message via AIM to Zappa's 68
Default Alignment specs - '68 GTO
Need alignment specs for '68 GTO. Power steering. Thanks!
Old 04-14-2023, 09:49 PM
1968GTO421's Avatar
Do you need factory alignment specs or the specs for improved handling? I've seen the latter specs somewhere on the street section.
GTOAA--https://www.gtoaa.org/
Old 04-14-2023, 10:04 PM
dataway's Avatar
dataway dataway is offline
This is what I have saved in my files on this subject. Taken from this forum ... but I don't know if they are factory or not.
Old 04-18-2023, 02:53 PM
Thank you...I'll give it a try!
Old 04-18-2023, 06:38 PM
Factory specs are the same for manual and power steering, which tells you that they weren't sweating the details. In general with radials and power steering go with caster slightly positive rather than the negative caster factory spec.
Old 04-18-2023, 08:07 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
These are the specs from GM service manual.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
