On a 66 2+2, Cat, Bonneville, GP, etc, is the fuel sending unit mounted on top of the tank or on the forward facing wall? The reason I ask is this particular car has a replacement tank in it and it mounts from the top and the sender is out of calibration big time. I'm seeing conflicting information searching for a sender.
On all of the US ‘66 full size Pontiac’s I’ve seen with factory tanks (not including wagons), the sending unit mounts in a recess in the middle of the top forward edge of the tank. The fuel lines coming out of the sender point directly forward towards the front of the car. I can supply pictures if needed.
Sent from my iPhone using Tapatalk |
" Darksiders Rule "
Thanks for the info guys, I bent the pick up lower which also lowered the sending unit in the tank. It works perfectly now. Thanks again.
