Old 04-17-2023, 07:52 PM
mysticmissle's Avatar
Default Aluminum block head studs what are you using
What are you heads using and where did you get the studs? Are you using different studs then you may have used on your iron block ? Tia
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 04-17-2023, 08:58 PM
chiefbigb chiefbigb is offline
They are not the same. I believe Paul k can get you what's needed
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 04-18-2023, 06:51 AM
in my research the only thing i have found ''readily available" are edelbrocks. spoke w ARP yesterday, and there are very limited off the shelf options in the lengths and thread sizes required for Hi ports and i would assume tigers as well, that have the recommended bullet nose in the block.
Do MR1A blocks use bullet nose style head studs?
1964 540 gto
Old 04-18-2023, 07:36 AM
AG's Avatar
AG AG is offline
I got my set from ALLPontiac, they have them custom made by ARP and they ain't cheap. They are longer to get better thread engagement.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 04-18-2023, 08:18 AM
You run eheads that’s what I’m
Saying
1964 540 gto
Old 04-18-2023, 09:03 AM
slowbird's Avatar
slowbird slowbird is offline
Paul K just posted on FB a build he's doing with HP heads, might want to ask him what studs he's using
Old 04-18-2023, 09:14 AM
Already went there and it’s an mr1a
1964 540 gto
Old 04-18-2023, 09:36 AM
mgarblik mgarblik is offline
I think it depends on the cylinder pressure/HP you are planning to make. On the recent Aluminum AP block I built with high ports, I just used the studs provided by Kauffman. But this was a modest 600 HP build. The provided studs DID NOT take advantage of all the extra thread engagement AP provides in these decks. I had just over .800" thread engagement in the deck. If I remember right, the AP aluminum blocks are tapped 1.25" or possibly 1.50" deep. For a high HP build, some longer studs would be better if you can find some. About all you can do is figure out what lengths you need and start calling vendors to see what may be out there. I see you were concerned about the bullet nose used in some aluminum applications. Depending on what you end up with. If you have long coarse threaded ends, you can make your own bullet nose on the ends. In my case, I didn't want to give up any threads at the bottom, so I set the studs with Locktite 271, high strength in a floating position. Bottom the studs and back out 1/4 turn. Mark the stud on top so you can make sure it doesn't turn when tightening the nuts. You just don't want to distort/tear the deck by bottoming the shank of the stud into the deck surface. You will need some heat to remove them when the time comes. You could burn up allot of time chasing special studs for this application.
Old 04-18-2023, 10:30 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
On my IA-II Iron block I used qty-18 6 5/8" ARP2000 from Outfront Motorsports and cut them down as needed. The other 2 short ones I needed for the RAV heads I found on ebay.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 04-18-2023, 06:47 PM
younggto younggto is offline
If you can’t find the correct dog point studs for an aluminum block you can put a ball bearing in first instead of modifying the stud; maximum thread engagement should be exercised.
