Solid lifter Q
Can you use Chevy solid lifters in a 400 Pontiac with a SFT cam? Any reason you can't?
69 Firebird 472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120 |
For awhile in the 80s you could not get a Pontiac solid lifter. So I ran Chevy solids with a longer pushrod. I did not have any issues with them.
Its not just a push rod lenght issue, sometimes being able to use them in a Pontiac depends on the base circle diameter of your Cam .
If the oil band drops out below the bottom of the lifter Bore then it's by by lifter Bore once you start the motor or soon after.
