Old 04-19-2023, 08:56 PM
Mike S's Avatar
Mike S Mike S is offline
Default timing on plug ground strap
I read that the heat line on the ground strap should be at the bend. Mine is a little closer to the base. It runs great. Do you think I should take a tad of timing out. I forgot what I set it at but I think it was 38. E-heads with 12-1 compression.
Last night I ran 6.30 with a 1.340 60'
ID:	611048   Click image for larger version
Old 04-19-2023, 10:58 PM
Elarson's Avatar
Elarson Elarson is offline
Taking timing out will move the color closer to the base.
When we ran the Grocery Getter, the nitrous experts recommended tuning the timing to put the color at the bend. We beat up a lot of pistons following that advice. Then started retarding the timing and every bit that we took out made it faster and easier on pistons. When the pistons were happy, the color was at the base of the ground strap.
FWIW:
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 04-19-2023, 11:06 PM
Tom Vaught's Avatar
Boost Engineer
FWIW:
Eric
I have seen a lot of engines killed by 1 degree too much timing and a lot of very fast engines (with happy pistons) when the timing was a lot less than what many thought it should be.
I have seen a several boosted engines make excellent power with less that 10 degrees of timing at max boost and max rpm.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 04-20-2023, 06:47 AM
charlie66's Avatar
I would take 2 to 3 out .
My Half AN Injun.....
The Following User Says Thank You to charlie66 For This Useful Post:
Old 04-20-2023, 06:52 AM
steve25 steve25 is offline
If that color change over point was not made by just full throttle runs and then shutting the motor down then you need one step colder plug, but even if it was the heat range looks like it’s on the edge of too hot to me.
One things for sure buying and testing another set of plugs is a heck of a lot cheaper then the cost of pounded out rod bearings!
Old 04-20-2023, 07:44 AM
The bend is for heat range of plug.
Timing is taken from the base of the bend. The whole circle of the flat part.
Old 04-20-2023, 08:41 AM
grandville455's Avatar
grandville455 grandville455 is offline
FWIW:
Eric
I thought less timing would move that mark more towards the tip and not the base? That's how i've always understood it atleast
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
The Following User Says Thank You to grandville455 For This Useful Post:
Old 04-20-2023, 08:58 AM
bluegoat65 bluegoat65 is offline
Nice looking plug. Maybe take out a couple degree. How does the fuel ring look down below...lol. Cut one apart and take a looksie.
Old 04-20-2023, 09:06 AM
x2 here
Old 04-20-2023, 09:08 AM
Scott65's Avatar
Scott65 Scott65 is offline
As mentioned, I'd take a new 3923 and 3922(or NGK equivalent as I like them better) and make a clean run to check heat range. It looks a little hot. (if you get the same heat mark on a new plug) I'd make a guess(though an educated one) the 3922 will be appropriate in a 12:1 engine. Once the heat range is verified, timing by power numbers(appropriate fuel is assumed)
'65 Tempest 467 3650# [email protected]
Old 04-20-2023, 10:37 AM
With night time runs the humidity usually soar’s and can make for your jetting looking fatter and allow you to run more timing then you could during mid day runs for example.
Old 04-20-2023, 10:40 AM
racegto65's Avatar
racegto65 racegto65 is offline
Good info in this video from Steve Morris about reading plugs
https://www.facebook.com/watch/?ref=...59749171308412
The Following 2 Users Say Thank You to racegto65 For This Useful Post:
Old 04-20-2023, 12:43 PM
Elarson's Avatar
Yes, you're correct. I said it backwards.
Retarding the timing reduces the temperature in the chamber and causes less cooking of the groundstrap; so the color band moves out toward the tip. The base of the strap sinks heat into the metal shell and stays cooler.
Grocery Getter ran best with almost no "blue" on the ground strap.
Sorry for the confusion...
Eric
The Following 2 Users Say Thank You to Elarson For This Useful Post:
