Old 04-23-2023, 10:18 PM
kpbrown31 kpbrown31 is offline
Default Catalina spindles
Looking for front spindles for my 66 Catalina wagon. I think spindles from 65 or 66 will fit? Thanks
Old 04-23-2023, 11:19 PM
Correct. 67-68 are the same except lower steering arm holes are 1/2" instead of 7/16".
Old 04-24-2023, 10:45 AM
So a guy could use 67/68 spindles with a little modification? I can’t think of the correct name, but basically you’d drill out the hole to a 1/2” on the steering bar that spindle bolts to?
Old 04-27-2023, 10:13 PM
And correct me if I'm wrong, but I haven't found anywhere that makes an aftermarket reproduction of them?
Old 04-27-2023, 10:52 PM
those are almost in zero demand - no repops.
Old 09-04-2023, 01:23 PM
newmexguy newmexguy is offline
There's a '67 Delta 88 four door sedan in an East El Paso yard. Drum Car. I have no idea if there is any interchange here. The olds used a "speedo" cable deal, used on the left front backing plate, that may be proprietary to Olds.
Old 09-04-2023, 02:53 PM
Completely different animal. Not till 1971 did the spindles interchange for full size.
Old 09-04-2023, 09:24 PM
70ra455's Avatar
70ra455 70ra455 is offline
I should have s set from either a 66 or 67. How can I tell?
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 09-04-2023, 10:50 PM
Post a pic.
Old 09-06-2023, 02:44 AM
70ra455's Avatar
Here they are.
Please contact thru text or phone. Much easier and more timely from my end.
908.208.7778
I'm in metro Detroit/Ann Arbor
Phil
ID:	619488   Click image for larger version
ID:	619489   Click image for larger version
Old 09-06-2023, 09:49 AM
Those are 69-72 "A" disc - won't work with full size.
Old 09-06-2023, 03:31 PM
70ra455's Avatar
Thanks for the info! Now I know what they are. Greatly appreciated.
