Old 04-30-2023, 02:57 AM
CatalinaWMixxer's Avatar
CatalinaWMixxer CatalinaWMixxer is offline
Default 63 and a half or 64 Pontiac Catalina
I purchased my car back in 2022. At the time of purchase I didn’t know much about the car, neither did the seller. The car has good bones, and no serious problems. After doing a few days post purchase I noticed that the car had a 63 front end and hood, but the title and the fact plate on the firewall matched a 64.
I reached out to some guys in Facebook groups. They told me either it’s a 63 and a half or it’s a 64 and someone swapped the front end. Can some one lead me in the right direction? Trying to source parts for these cars isn’t as easy as going to the junkyard.
ID:	611699   Click image for larger version
ID:	611700   Click image for larger version
ID:	611701   Click image for larger version
Old 04-30-2023, 07:59 AM
Stuart's Avatar
Stuart Stuart is offline
Go by the number on the trim tag, it's a 1964 car that someone put a 1963 front clip on. There wasn't any sort of 1963 1/2 car. Your VIN tag on the car's title (as well as on the driver's door pillar) should also decode to a 1964 car; you can look at the VIN decoding information at http://www.1963pontiac.com/tools.htm or https://www.tpocr.com/pontiacvin.html
The Following 3 Users Say Thank You to Stuart For This Useful Post:
Old 04-30-2023, 10:05 AM
misterp266's Avatar
It’s a ‘64 with a ‘63 nose. Dash is ‘64. Rear quarters are ‘64. If you want it right, look for a ‘64 nose.
Edit: after looking again, it looks like a ‘63 dash but quarters are ‘64. Looks as is someone cobbled a few cars together.
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post:
Old 04-30-2023, 11:07 AM
pfilean's Avatar
pfilean pfilean is offline
What I see is a 64 that has been wrecked and had a 63 front clip put on. If they did that I would start looking for damage that may not have been repaired well. Like frame and suspension.
The Following 2 Users Say Thank You to pfilean For This Useful Post:
Old 04-30-2023, 01:16 PM
I have been looking already. I’ve sourced a whole nose cone assembly and a grill assembly for 600.
The Following User Says Thank You to CatalinaWMixxer For This Useful Post:
Old 04-30-2023, 09:43 PM
Can't be the same car but in the late 1960's I sold a 1963 nose for his 1964 Pontiac.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 05-01-2023, 03:34 AM
I mean it could be the same car very slim chances lol don’t suppose you have a 64 nose laying around?
Old 05-01-2023, 09:11 PM
Do yourself a favor and ditch the Slim Jim for a TH400. It’s a pretty straight forward conversion.
Dr. Thomas Sowell
Old 05-02-2023, 05:57 AM
Is there an adapter plate I would have to buy?
Old 05-02-2023, 08:52 AM
Keith Seymore's Avatar
Some combinations:
If your starter mounts to the block, and you find a BOP pattern TH400 - then no.
Starter mounts to block, Chevy pattern trans - yes.
If your starter mounts to the trans:
BOP TH400 - you would use a starter mounting plate. You could purchase one, or fabricate one your self based on plans in Pete McCarty's book.
I have a '67 Buick TH400 in my '63 Grand Prix, by using a starter mounting plate.
K
'63 LeMans Convertible
'63 Grand Prix
