Hi!
Just got started aligning the front end, having the endura bumper is going to give me a headache for sure... Anyway. When i disassembled the valance panel along with the parking lamps i had roughly 5 types of bolts altogether... Some fine, some coarse... I've searched the restoration guide and both shop manuals for correct ones without any luck. I was hoping someone in here could shed some light on what bolts might be correct. /Adam |
All of those bolts attached to clip nuts and that's what's going to determine whether it's a fine or coarse thread. Sounds like you might have a mixed bag...With that said, I can't tell you what the original configuration was but I can't imagine that they had a mixture of coarse and fine threads from the factory.
Greg Reid Palmetto, Georgia |
| The Following User Says Thank You to Greg Reid For This Useful Post: | ||
If you go to AMK and type in “G-7401” they will break down all the fasteners needed and include pics of each piece. G-7391 is the parking lamp hardware.
99% of what I’ve received from them in their Master Kits has been spot on. The valance hardware listed above fit perfectly for me, although I never had original hardware there when I got the car to compare it to. https://www.amkproducts.com/search-result/?ser=G-7401 https://www.amkproducts.com/search-result/?ser=G-7391 Main master kit directory: https://www.amkproducts.com/master-k...fastener-kits/ |
| The Following User Says Thank You to Entropy11 For This Useful Post: | ||
Thanks for your replies!
I saw Ames carry correct ones aswell. Usually takes 3-4 weeks to receive a parcel but if thats the only way i guess i'll take it. |
Mvh Håkan
`70 GTO, 370 hp, 3:90, TH400. |
| The Following User Says Thank You to hakansan For This Useful Post: | ||
Hi Håkan! Totally forgot about Americano, gonna try keep it in mind next time... Ames have already charged and shipped my order. Thanks for reaching out tho, take care
The kit is excellent. It is a little pricey, but I believe that it is worth it. |
