Old 05-06-2023, 02:40 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Default 6 point roll bar certification
Just put a 6 point bar in the Trans Am. Can't seem to find any info on getting it certified. Plenty of information on 8.5 certification but very little on cars like mine that will be in the 11.49 down to 10.00 bracket. Is there a fee and a decal that is required plus renewal every 3 years like the 8.50 cars?
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
Old 05-06-2023, 03:18 PM
johnta1 johnta1 is online now
It's been probably 15 years since I was tech inspector but think it's still only 9.99 ET or 135 MPH need a cage certified.
Tech guy at track will make inspection to see if it's not some exhaust tubing or bad welding probably, but no sticker on tubing.
Old 05-06-2023, 03:28 PM
AG's Avatar
AG AG is offline
No certification needed for 6 point roll bar down to 10.00, certified cage is needed 9.99 or faster.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
The Following User Says Thank You to AG For This Useful Post:
Old 05-06-2023, 03:32 PM
Thanks guys. I was hoping that was the case.
