Old 05-11-2023, 09:04 PM
dbiggs dbiggs is offline
Default Shifter mystery...to me anyway
When I bought my GTO to restore it came with this shifter that appears not to be correct. It doesn't have any mounting tabs in front. Does this belong to a different model Pontiac?
Resto almost done - 1966 GTO HDTP Tiger Gold (paint code 1-2), black vinyl top and interior, 389 tripower, 068 cam, TH-350/Hughes TC, RA manifolds, 2.5" Pypes exhaust, Scarebird Front Disc, Ralley II's, factory PS, PB, PW, PA, A/C, headrest option.
Old 05-11-2023, 11:49 PM
Sirrotica's Avatar
I always thought they called them mystery shifters, because you never knew what damn gear it was in.............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-12-2023, 12:04 AM
ZeGermanHam's Avatar
Your shifter appears to be missing the front feet for bolting to the trans tunnel. Not sure if someone cut them off or what, but it should look like this:
1998 BMW 328is (track rat)
Old 05-12-2023, 01:49 AM
Geoff Geoff is offline
It is missing the rear feet. Easy enough to make new ones.
Old 05-12-2023, 01:54 AM
Ham is correct, front feet are missing.
Old 05-12-2023, 03:50 AM
242177P's Avatar
242177P 242177P is offline
If it's a proper restoration, the carpet gets sliced down the middle
of the tunnel. Not sure how long the cut should be. It's probably
an order of assembly kind of deal. The thick washers under those
bolts? They're actually spacers, they go under the shifter. HTH.
Old 05-12-2023, 04:12 PM
Angry
Yeah strange...I guess I'll ditch this one and try to find the correct one
Old 05-12-2023, 07:59 PM
If you're able to weld, it would be pretty easy to attach some feet on your existing shifter. Heck, you could probably just bend up some scrap steel tabs, drill some holes and bolt them to the shifter. Since reproductions don't exist, the original 2-speed shifter assemblies are kinda pricey for what you're getting.
The Following User Says Thank You to ZeGermanHam For This Useful Post:
