Old 05-27-2023, 02:50 PM
Zooguy Zooguy is offline
Default Rear lower control arms
1966 Pontiac Bonneville four-door hardtop.
I picked it up as a parts car but this thing is wanting to run as in a lot better condition than what I thought so I'm going to make it just a basic driver for the wife. I installed a new master cylinder up front for the brakes and then moved to the passenger rear to start bleeding brakes and when I removed the wheel I discovered the passenger rear lower control arm is severely bent.
Does anybody make these or do I need to try and straighten it out?
Old 05-27-2023, 02:54 PM
A good used one is what you should be looking for. Demand for new ones is practically zero so nobody is making new ones.
Replace it. I wouldn’t bother trying to straighten it.
Old 05-27-2023, 03:26 PM
Stuart's Avatar
Stuart Stuart is offline
They aren't cheap but PMT Fabrication sells upgraded control arms for your car: https://pmtfabrication.com/product-c...ville-catalina
edit: they sell a kit, with adjustable uppers and boxed lowers. For a street car that's not meant for high performance they're probably overkill, I agree that finding some used OEM replacement parts is a better choice.
Old 05-28-2023, 12:51 PM
imposter's Avatar
imposter imposter is offline
i had a set of adjustable uppers and fixed lowers made from spohn
Old 05-28-2023, 02:15 PM
Check with a specialty supplier like Franks Pontiac Parts out in CA for a correct nice condion used lower control arm.
