Old 05-30-2023, 10:35 AM
69Nok 69Nok is offline
Default 69 Basket Case Bird - Need some help with Headlight Harness Routing
Questions for the team. Trying to figure out the correct routing of the healight harness and ground location on the basket case bird. That particular page on the manual is so faded I cannot tell exactly where things go. Here’s a couple of pix of the areas in question. Thanks in advance.
ID:	613410   Click image for larger version
Old 05-30-2023, 10:44 AM
JLMounce JLMounce is offline
The forward light harness runs atop the passenger inner fender well and has I believe one or two push clips that slot into holes on the wheel house cover itself. The Grounds attach to the upper filler plate of the nose section. There should be notches there that the grounds come up through the bottom. They will be located about 4-5" inboard of the fenders.
Based on your pictures and the current status of front end construction, I would simply lay that harness out in its general location for now. When you get the driver wheel tub in place, you can run the harness there. When the front end goes on, you can complete the harness there.
-Jason
1969 Pontiac Firebird
Old 05-30-2023, 11:48 AM
Thanks for the response. I'm really looking for specifics in the areas pictured. Pass side there are a few locations where the push clip on the harness can be installed to the core support of the extension. It appears that the grounds loop around to the opposite side (radiator side) of the core support (over? under?) the extension and a screw into one of several similar sized holes to attach.
Driver side, yeah fender well is the easy part.. Same as pas side for the grounds and it kind of looks like the push clip of the harness itself goes into the hole halfway up the extension sot he harness would go up and over the extension at that point?
Old 05-31-2023, 10:19 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
I highly recommend that you purchase a factory assembly manual for the 69 firebird. It has detailed images along with the part numbers.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 06-01-2023, 02:12 PM
Yeah, here's the page showing the installation.
Old 06-14-2023, 09:43 AM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default Finished?
69Nok, did you get your harness installed? Can we get a few pics of it completed as I am right where you were a few weeks ago. I have a digital copy of the Assembly Manual but pics are small and grainy so not much help. Thx. Dave
1970 T/A
Old 06-14-2023, 09:52 AM
I got my questions answered. That page of the manual - SUCKS.
