Old 05-30-2023, 04:11 PM
jhein's Avatar
jhein jhein is offline
Default Carb vacuum nipple
When I was troubleshooting my Qjet recently, when I removed the vacuum line for the choke pull off, the hose was very tight and pulled the nipple out of the carb body. I plugged it back in and it feels snug and it operates the pull off. Should I use something like locktight on it or just leave it?
Old 05-30-2023, 06:01 PM
steve25 steve25 is offline
I have had that take place on me and I forget what size I used, but I tapped in a long taper center punch to flare the tube out I bit and then drove it back in the carb with a wood block.
I also think I may have used whatever size drill bit to put a slight chamfer on the carb body to help get that flared out end started.
Old 05-30-2023, 06:21 PM
gtobird's Avatar
gtobird gtobird is offline
Well, when you remove the various tubes from the airhorn (inside the quadrajet), it's common practice to put them back in using red loctite. In fact, did that last week. The point being, I don't see how this would be any different. Just make sure to keep it only on the outside of the tube before knocking it back in.
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
The Following User Says Thank You to gtobird For This Useful Post:
Old 05-30-2023, 06:29 PM
Formulajones's Avatar
Yep, happens occasionally. Like said, put a little loctite on it, put it back in and forget about it. It'll be fine.
https://youtu.be/XqEydRRRwqE
Old 05-30-2023, 07:00 PM
Schurkey Schurkey is offline
Yep. Whether it's an existing nipple that pulled out, or a modification to add a nipple where there wasn't one before, a dab of threadlocker on the tubing works wonders.
The Following User Says Thank You to Schurkey For This Useful Post:
Old 05-30-2023, 08:37 PM
jhein's Avatar
Thanks gents
Old 05-31-2023, 08:12 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Nipple <snicker.....>
heheheheheheeeee
Clutch Guys Matter
_______________________________________
53 Studebaker, 400 pontiac
72 4-4-2 Mondello's VO Twister II
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
Old 06-03-2023, 02:41 PM
Yup, nothing wrong with a little lube on the nipple!!
