Old 06-01-2023, 09:41 PM
433lemans's Avatar
433lemans 433lemans is online now
Default Valve Spring Installed Height Tolerance
Is there an IH tolerance or should they each be installed exactly right on the recommended IH?
Old 06-01-2023, 10:00 PM
Steve C. Steve C. is offline
"An installed height of +/- 0.020 inches is acceptable."
https://www.motortrend.com/how-to/16...spring-height/
Once you have determined the shortest installed height, it will be necessary to use shims to obtain this height (±.020” is acceptable) on the remaining valves.
https://www.compcams.com/valve-springs-101
I've seen one source that stated +/_ 0.010 but that was not the norm
Old information here:
The Following 2 Users Say Thank You to Steve C. For This Useful Post:
Old 06-02-2023, 06:17 AM
steve25 steve25 is offline
Other then having the needed minimum retainer to seal, or retainer to guide clearance the installed height is all about the spring.
The installed height needs to provide the minimum seat pressure as stated on the cam card while NOT having the installed height such that the spring is at coil bind.
On most duel spring set ups I have used for a non roller hydro cams in motors that can buzz to 6000 rpm, the use of a .030” shim will add 10 psi to the seat pressure.
When setting up the installed height with new springs I almost aways add a .030” shim just to compensate pressure loss once the spring breaks in.
If it’s for a small valve head 1.96”/ 1.66” and I already have the 125 seat pressure I like to start off with and if I know the motor will not need to go above 5800 then I might leave out the .030” shim.
This applies to a true duel spring set up.
If due to the customers choice I am using a set up that is only a outer spring and a flat wire damper, the. I do add the .030” shim.
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 06-02-2023, 07:00 PM
wolf's Avatar
wolf wolf is offline
If you want to be obsessive, it's the spring forces you want to equalize, not necessarily the installed heights... so installed heights end up being whatever is needed for each spring.
The Following User Says Thank You to wolf For This Useful Post:
Old 06-03-2023, 09:15 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
And then the question whether equalizing pressure(the theory behind equal IHs) is will the motor really notice a difference of 5 or 10 lbs on the seat?
Skip Fix
Old 06-03-2023, 09:11 PM
Joe37 Joe37 is offline
You can only be as close as the smallest shim, which is .015". You could try moving valves around and changing retainer and keepers, but at the end of the day, .015" to .020" is good enough.
If you are really worried about .015" difference at zero lift, check each lobe of the cam and each rocker arm for the correct lift and ratio, then see if .015" really matters.
The Following User Says Thank You to Joe37 For This Useful Post:
