Tri-Power Tech 57-66 Tri-Power Talk
Old 06-07-2023, 06:12 PM
misterp266's Avatar
Default Updated Tri Power Intake by KRE
Here’s a peak at Kauffman’s new intake. Says it’s good to about 750 HP.
Uses either Rochester or Holley carbs.
ID:	613871   Click image for larger version
" Darksiders Rule "
Old 06-07-2023, 06:34 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Any idea if they will be available for Norwalk ?
Old 06-07-2023, 06:36 PM
Removable top so you can work the insides and choose whatever carburetor style and coolant crossover already separated.
According to their website as cast is $715 with crossover for either style, port matching from 290 cfm through 400 cfm at $75 up to $200. Quite reasonable actually.
Game changer.
About time someone stepped up and brought something like this to market.
No surprise that the Kaufmans made this happen.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 06-07-2023, 10:43 PM
RocktimusPryme's Avatar
They said they would be offering carbs as well. I asked in FB if anyone was offering 2300s set up for a tripower and they said they would be.
Holley sells the kit with intake for a small block but to my knowledge they don’t sell the carbs separately.
Old 06-08-2023, 04:47 AM
3X24SPD 3X24SPD is offline
Love it.
Just placed my order.
Timely Happy Birthday present for me & my '65!
Thanks for posting!
-Bill
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
The Following User Says Thank You to 3X24SPD For This Useful Post:
Old 06-08-2023, 05:10 PM
misterp266's Avatar
Default Video
https://fb.watch/l1-eIQks6r/
With 3 Holleys.
" Darksiders Rule "
Old 06-08-2023, 05:30 PM
tom s tom s is offline
Be nice if they made a 2-4 top,lots of hood room.Tom
Old 06-08-2023, 05:37 PM
Lightbulb
I’m sure they are watching the forums to gauge interest and reactions.
Never hurts to give them a call and put in your two cents either.
Old 06-08-2023, 05:40 PM
JMHO,2 carbs are always better than 3 for many reasons.Tom
Old 06-08-2023, 05:41 PM
brut4s's Avatar
brut4s brut4s is offline
According to their Facebook post a dual quad top is among the options coming for it.
The Following User Says Thank You to brut4s For This Useful Post:
Old 06-08-2023, 10:49 PM
misterp266's Avatar
Don’t be so humble Tom!
FYI, I have never been a fan of tri power…….dual quads always! Just posting for those who disagree.
" Darksiders Rule "
Old 06-08-2023, 10:50 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Very exciting. Besides the weight savings and superior casting to the old alu tripower- curious what u guys think this would do for my set up?
461, kre 290 d ports, raiv cam, 1.65 rockers, ram air manifolds, tripower with opened up carbs, stock intake. 3.36 gears and a tkx.
Wondering if the new manifold would hurt low end torque? What else should I expect? I am a stop light to stop light guy. Not much 1/4 mile…thoughts appreciated.
I just asked jeff the same.
Old 06-08-2023, 11:35 PM
Would look super cool.
That’s enough in my book.
You have plenty of cubes so a single plane intake would still have plenty of low end torque, with a stick shift it would be awesome.
Sorry if I was getting too technical there.
Tri-Power is the Pontiac signature street setup, run with it !
Old 06-09-2023, 12:57 AM
Dick Boneske's Avatar
Would be interesting to see a HP comparison between the Holley two barrels vs. real Tri-Power Rochester Carbs.
The stock end carbs flow very well, and the center carb would be better by far for MPG on the street. Anyone who has used Holley carbs on the street knows they use a lot more fuel than many other carbs.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-11-2023, 08:14 PM
Tom Vaught's Avatar
Boost Engineer
Truth Above, (unless you know how to tune a Holley 2-BBL properly), LOL.
Tom V.
Old 07-27-2023, 05:53 PM
mike w mike w is offline
Default Comparison Rochesters to Holleys KRE
I have supplied KRE with a modified set of Rochesters. All three have been opened up to 1 3/8”, in venturi area. Their plan is to do a Dyno pull on same motor, comparing them with the Holleys.
Results will be interesting.
The Following 3 Users Say Thank You to mike w For This Useful Post:
Old 07-27-2023, 06:42 PM
Can’t wait!
Old 07-27-2023, 11:14 PM
Fantastic! I hope the 2G's are jetted correctly. With 1 3/8" venturi's, they'll need at least .073" jets.
I've opened up a pair of 683's also, to 1.4375"', which is as far as you can go without breaking through the walls. Have not had them on a running engine.
BONESTOCK GOATS
Old 07-28-2023, 05:35 AM
I've had mine installed & running for a couple weeks now.
My carb venturis are opened up as well.
Overall, I'm really happy with the performance results.
Quite a difference from my old worked intake.
Just as an FYI, anyone who expects this to be a quick 20 minute swap as I did will be somewhat disappointed.
Several issues, the most significant including:
1) Required a .065" correction cut.
I've had 3 different TriPower intakes on this same motor previously- none of which required a correction cut.
2) 1/4" interference between the back of the intake and the distributor.
I had to grind .125"+ off both the distributor cap and the back of the intake.
3) Machining required to eliminate airflow obstruction on all three carb flange ports.
There's a few other things, most minor stuff. Here's a couple:
Need to drill & tap in 3 locations if you run PB, PCV & VA.
The bolts included are stock length- but the intake mounting flanges are 1/4" thinner than factory- so the bolts bottom out in the head threads before they make contact with manifold. The ports are tall & wide- so the small diameter 3/8" 12-point heads supplied are necessary for clearance. I replaced with 1/4" shorter socket heads.
The ports are tall- so the valve cover lips need to be clearance as well.
There are shortcomings in the engineering design department- most notably the width of the carb flanges and the lack of material underneath them at the entrance to the plenum to accommodate proper airflow. There's not enough meat there to open up & correct that short turn.
ID:	616845   Click image for larger version
ID:	616846   Click image for larger version
ID:	616847   Click image for larger version
ID:	616848   Click image for larger version
The Following 2 Users Say Thank You to 3X24SPD For This Useful Post:
Old 07-28-2023, 05:37 AM
Default Old Intake
This is the manifold I was previously running.
It's a worked over Wilson ported first run PY (US made with no core shift)
