Old 06-08-2023, 11:27 AM
ejw's Avatar
ejw ejw is offline
Default Convertible side window weatherstrip replace
How do I replace side window weatherstrip - small rear seat window. Do I pull off chrome strip off window to replace rubber or do I just slide rubber out
Thanks Eric
Old 06-08-2023, 01:40 PM
Assuming you are referring to the vertical weatherstrip on the front of the quarter window, it just pulls down. It was held into the chromed molding with a bit of weatherstrip glue.
Old 06-08-2023, 03:30 PM
ejw's Avatar
ejw ejw is offline
My originals are rotted and tough to compare to new piece. There is a tab that sticks out bottom when slide rubber in window.
Where does this attach to
Old 06-08-2023, 04:43 PM
the bottom "hook" in the rubber just sort of sits there, since repro's aren't as rigid there you might want to glue them
Old 06-08-2023, 05:11 PM
ejw's Avatar
ejw ejw is offline
Thanks for help
Old 06-08-2023, 09:22 PM
Tim john Tim john is offline
Regular blue Dawn dish soap helps the new rubber slide easier as you push, pull and coax the new seals into position. Lube up the new seals generously with the dish soap.
Tim john---
The Following User Says Thank You to Tim john For This Useful Post:
