Old 06-30-2023, 06:41 PM
64-389's Avatar
64-389 64-389 is offline
Default 64 LeMans Rear End
What rear end options came with the 64 LeMans 326 package?
Tom
1964 GTO Custom Convertible
Old 07-01-2023, 08:30 AM
The Champ's Avatar
3.23 was standard with a 3.08 optional for either the 2bbl or 4 bbl LeMans with the 326.
Old 07-01-2023, 09:13 AM
64-389's Avatar
Thank you!
Tom
Old 07-01-2023, 10:22 AM
Bill Hanlon's Avatar
There were a few more options available. Below is from the '66 Pontiac Chassis Parts Manual.
ID:	615221   Click image for larger version
Old 07-01-2023, 01:31 PM
64-389's Avatar
Thank you as well!
Tom
Old 07-06-2023, 12:53 AM
bbnotop bbnotop is offline
My '64 326, 2 bbl, ST 300, had a 2:56 open rear end.
Old 07-06-2023, 02:08 AM
My Le Mans convertible was factory equipped with a 250 hp 326 2-barrel, ST300 2-speed auto and a 2.93 open rear, also has factory air conditioning.
Old 07-06-2023, 08:10 AM
64-389's Avatar
That's kind of what I was afraid of. My '64 LeMans has a 2:56 open. I was eyeing up a 326 LeMans with a bad frame just for the possible posi with higher gearing. But's it's gone from FB marketplace now....=( The search continues.
Tom
Old 04-09-2024, 03:11 PM
64-389's Avatar
If anyone is curious, I did a rear end swap this winter. Installed the Yukon 3.55 Duragrip posi. The rear end I pulled out calculated to a 2.78 open. That's from my car which originally was a 215 IL-6 LeMans with a 2-sp Air Cooled AT.
Tom
The Following User Says Thank You to 64-389 For This Useful Post:
Old 04-10-2024, 08:28 AM
johnta1 johnta1 is online now
I'll bet it feels like a whole new car!
Old 04-10-2024, 03:32 PM
64-389's Avatar
Oh Yessirrr! I'm about to reach the 100 mile break in and then I'm really gonna let it rip!
Hope to be much better prepared for Norwalk this year.
Tom
Old 04-10-2024, 04:50 PM
Cammer-6 Cammer-6 is offline
might be too late for you but I learned a trick about breaking them in
put the car on lift or good solid jackstands and let it idle in gear for at least 30 minutes.
A buddy that had a trans shop showed me this.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-12-2024, 10:43 AM
64-389's Avatar
That's a good idea. Too late for my car, yes, but we're also thinking about changing my Dad's out. We can certainly use it for that!
Tom
