Old 07-06-2023, 05:09 PM
Yellow Bird Yellow Bird is offline
Default Radiator Shroud Restoration
Nu Finish Scratch Doctor was recommended to restore my radiator shroud. This is not working. Any suggestions would be greatly appreciated. Is there a rattle can paint I should use?
Old 07-06-2023, 07:06 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
My 8-track player cover is black but had a whitish haze over for some reason. I used this stuff and it looks like new. IF it were me I would try it on my shroud, just saying.
Old 07-07-2023, 08:11 AM
78Macho 78Macho is offline
Default shroud
Burd-
I guess you could try wet sanding the scratches out and then polishing them back up some?
Seems like the plastic refinish paint might take away all of the veining in the original plastic product?
I use Vaseline on my shroud for a fresh finish.
Jim
Old 07-07-2023, 09:44 AM
Trevor78 Trevor78 is offline
heat gun all over it first to take haze off the surface, try out of sight first, then a buff with a black rubber/plastic trim polish. If that isn't working, not coming back to black, look at the various trim coatings mentioned. Matt black would be incorrect for this item, and would stain easily from coolant splash, still had a sheen when fresh.
Old 07-07-2023, 10:47 AM
78w72 78w72 is offline
It may not be 100% correct color but if you're not going for a concours resto, there is a spray can paint you can use that will have very good results & be a satin sheen that will look good. SEM color coat landau black, designed for plastic/vinyl and is a professional quality paint. Can buy it at most local auto paint stores or online from summit, jegs, amazon etc, or even walmart online if you prefer.... dont matter where you buy it, its a high quality paint that works great if prepped & applied right.
If you used any other product on the shroud it should be cleaned very good before paint, dawn dish soap with warm water or other strong grease/wax remover like simple green, then scuff up with a scotch brite pad or fine sand paper then a final wipe with rubbing alcohol is what ive always used to prep the numerous pieces ive painted, they all look great 7-10-15+ years later.
Heres a pic of a shroud on one of my cars i did years ago, being its a paint, coolant or other light spots of auto fluids wont stain it. If some gets on it, it wipes/cleans right off & the normal level of heat from the rad doesnt damage it.
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
Old 07-08-2023, 08:19 AM
Default Thanks so much
Thanks so much for the response guys. Not sure yet what I'll do, but at lease I have ideas to move forward. Thanks again everyone.
Old 07-08-2023, 01:03 PM
tstroud tstroud is offline
Some people say that boiled linseed oil restores the color in plastic parts like that. I'd try it on the inside first.
Old 07-09-2023, 04:22 AM
Probably the same effect as heating the surface so the oils refresh.
Old 07-09-2023, 03:51 PM
turbo69bird's Avatar
Try flood penetrol on a little spot se show it works first if it’s good that will last a long time.
I have been doing aluminum intakes - brackets etc
with my Vapor hone (blaster) set up. It works amazing because it rolls the glass bead or other media across the surface. Brings alluminum intakes to the like new perfect sheen
If I can find a damaged plastic shroud I’m going to test it on one because I think it would work really well to restore them to like new with appropriate sheen I’ve done some other parts with plastic on them and the plastic parts were like new coming out. It won’t remove RTV or anything like that from a part (like an intake gasket surface) it’s very gentile .
960 HP @ 11 psi, 9.70 at 146.
