Old 07-07-2023, 03:49 PM
mbeeman400's Avatar
mbeeman400 mbeeman400 is offline
Default Looking for Alternator Rear Support Bracket for 1970 TA
Need the rear bracket that attaches to water neck stud and alternator (see picture) Also need the water neck stud. TIA
[QUOTE]
Name:	Alt Bracket TA.jpg
Old 07-07-2023, 10:51 PM
Formulabruce's Avatar
1970 TA got #480517 brace, delcotron mtg. ( due to mandatory Power Steering) and it looks Nothing like your picture.
Group # 2.277
Old 07-08-2023, 07:42 AM
mbeeman400's Avatar
Group # 2.277
Pic is off ebay, I might not have the correct setup, but its what I need. Thx
Old 07-08-2023, 03:32 PM
Ramairnacho Ramairnacho is offline
Default 1970 brackets
I might have an extra set front and back I'll look when I get home and send pics tonight
Old 07-08-2023, 06:40 PM
Held for Ransom's Avatar
Front depends on what timing cover/water pump is used. Rear is '67-'69 setup. Available in repop.
https://www.ebay.com/itm/200912224219
So long, farewell.
Old 07-08-2023, 09:31 PM
mbeeman400's Avatar
Yes sir, thank you
mbeeman400's Avatar
Thank you
Old 07-09-2023, 01:00 PM
Default Brackets
Originally Posted by mbeeman400 View Post
Thank you
The 70 brackets 1 year only I didn't have extra but they reproduce them part place sells them bro here is the link
https://www.ebay.com/itm/33103618878...mis&media=COPY
Not bad for 100 bucks free shipping.
The Following User Says Thank You to Ramairnacho For This Useful Post:
Old 07-09-2023, 01:38 PM
Have a few of the rear alt to intake straps. Have loose intakes, ought to have a studded bolt.
Am always running out of the front strap that comes off the 11 bolt water pump.
Might double ck that your engine's P/S pump pulley's number ends in a "900" or "901", get a lot of calls & emails due to mismatched PS pulleys when dealing with '67 -70 Pontiac Alt/PS setups.
Old 07-09-2023, 04:47 PM
That's a good point , you should have a 70 water pump and 70 Intake and heads to work.take pics or tell us what heads Intake and water pump you have.
Old 07-14-2023, 09:16 PM
mbeeman400's Avatar
I have 70 correct "12" heads, Intake is correct, repop front engine cover, 11 bolt pump. Thanks
Old 07-14-2023, 11:12 PM
Default Brackets
I believe the repop link.i sent you is correct
Old 07-15-2023, 06:51 AM
mbeeman400's Avatar
Thank you!
