Old 07-08-2023, 06:52 PM
Nitebird Nitebird is offline
Default Small brake fluid leak in between my master cylinder and booster on my 1979 TA/SE
I was getting ready to drive my car (1979 TA/SE 4spd) and decided to check my brake fluid since I dont drive the car very often. I noticed that the rear bowl of the master cylinder was very low. I did some more looking around and I noticed that there is a small leak between the master cylinder and power brake booster.
Anybody know what might cause this? Would it be a bad master cylinder or something wrong with the booster.
Approximately 8 years ago I installed a new master cylinder and had the brake booster rebuilt by Booster Dewey.
I know all parts fail at some point but I just want to know if somebody else had something like this happen and what the cause of it was so i can fix it.
Any input is welcome and thanks!
Old 07-08-2023, 07:07 PM
If the back of the master is leaking, just replace it. Unless there is a kit to replace the seals. The rear wheel cylinders can leak also. Brake fluid rinses off with water. I dont think Brake Fluid in the booster actually hurts anything.
Bill Nye.
Old 07-08-2023, 07:20 PM
stevep's Avatar
stevep stevep is offline
Replace the master!
The Following User Says Thank You to stevep For This Useful Post:
Old 07-08-2023, 07:48 PM
72projectbird's Avatar
The master is leaking.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-08-2023, 07:54 PM
77 TRASHCAN's Avatar
The leaking brake fluid will eventually kill the diaphragm in the booster.
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 07-08-2023, 10:44 PM
I will replace the master cylinder then. Thanks guys!
Old 07-09-2023, 06:23 AM
steve25 steve25 is online now
Before you go thru all the effort to replace the master first try flushing / bleeding the whole system out.
Brake fluid should not have a light brown tint to it.
Many times I have had a small leak like that and it was due to very fine rust particles build up in the fluid, and there’s no type of hydraulic seal on the planet that will seal on grit.
Besides your going to basically ( or you should) flush the whole system out if indeed it does come down to needing a new master, and the cost of going thru one or two more can’s of brake fluid is small.
Also while your at it if both of your front brake hoses are original ( near 50 years old ! ) and so is your rear one likely, now is the time to change them out.
When they collapse on the inside ( which you can’t see) it takes more pedal pressure to apply the brakes, and it can also allow the brakes to hang up and then if nothing else your chewing up pads and brake shoes very fast.
Old 07-09-2023, 09:29 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
My master went the same way. Just replace the dumb thing lol
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 07-09-2023, 10:10 AM
How does it kill the booster?
Bill Nye.
Old 07-09-2023, 06:36 PM
geeteeohguy's Avatar
Brake fluid does not harm rubber. Other than displacing room in the booster with fluid, it will do zero harm. Agree with the others that the rear seal on the master is leaking and the master should be rebuilt or replaced.
Jeff
Old 07-10-2023, 07:12 PM
That was my thoughts also. Last one I had leak fluid into the booster, I used a vacuum hose connected from the intake manifold down the master hole to suck up any fluid. Then I poured some rubbing alcohol down there and sucked it out, hoping to get a majority of fluid out. Then connected everything normally. I figured the alcohol under engine vacuum, would evaporate out pretty well.
Bill Nye.
Old 07-11-2023, 09:27 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Brake fluid absorbs moisture causing humidity to start corroding the metal and then leak.
My 65 GTO and 64 Impala projects have rust holes below the MC in the firewall from leaking.
Skip Fix
Old 07-11-2023, 11:21 AM
glenn911's Avatar
glenn911 glenn911 is offline
I currently have the exact same issue on my '74. Where would one get a replacement master they can count on in this age?
