Finished up GP and have a bunch of leftovers that hopefully someone can use
-Two compressor tanks: Pic 1- Extremely nice tank with upper bracket to attach to core support. Intact, not opened up $150 Pic 2 -Good condition-with upper bracket, has been opened up, one small bolt broke in brass hex shaft to remove, bolt replaced however. Would clean up and look great. $100 Pic 3- bottom brackets that bolt to lower core support- Extemely nice one is $30, poor one is $5 Pic 4- 3 valves that mount near rear axle- best one is on the right- complete with all mounting hardware- condition is excellent $150. The center one is very good but will have some pitting on the arm lever and bracket to the upper control arm $100. The one on the left is missing the last bracket that mounts to the control arm, otherwise complete $50 Pic 5- line clips that hold air line on frame- nice originals 13 of them $40 Can bring to Norwalk or TA Nats Steve 519-525-3342 Last edited by comanchefirebird; 07-09-2023 at 05:43 PM. |
Pic 1
Two boxes of NOS air line which could also be used for air shocks (without self level) Box with 13'9" of NOS line $25 (which is more than enough to go from the compressor to the valve over the rear axle) Box with 24 feet of line $35 Two NOS line fittings - $15 each in original unopened bags Second pic- Two NOS "T" lines for air shocks. These would work on a 69 GP but the position of the "T" is off center (GP has the T in the center, ie each line to a shock is the same length). Both are the same and NOS $20 each |
Do you still have this stuff?
1970 "Real" Judge RAIII 4-speed, Atoll Blue w/painted white top. Mild RAIV headed 400 motor in now. |
Hi,
Yes I have everything that was listed. Drop me a text or pm with what you're interested in Thanks Steve |
Pm sent,
Nate
Much of this has sold
Moderator please remove thread I will start a new thread for items left Thanks |
