Old 07-10-2023, 08:36 PM
cnc's Avatar
cnc cnc is offline
Default Door panel screws
Can someone post pics of the screws in the door for the panels….I’m putting my panels back on and I’ve packaged my screws for the interior for the doors but I have way to many screws so I don’t believe I’m looking at the right stuff…. Thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 07-11-2023, 09:54 AM
78w72 78w72 is offline
Which panel screws do you need pics of? The only screws on the older panels are in the cup area of the lower plastic section that attach to the metal "shelf" bracket bolted to the door frame, then the short bolts that attach the inside door handle to the frame. theres also 2 or 3 screws with the attached washers that install where the upper plastic meets the top vinyl section, 2 at the ends & i think 1 other in the middle area. the rest of the panel should use the push in plastic & metal pins.
Im sure others will post pics for ya, but heres a link that shows most the screws locations, the 2 for the metal bracket are in the recessed area of the lower plastic right below the door inside handle.
https://i.pinimg.com/originals/f4/81...8715a7e9d1.jpg
Old 07-11-2023, 12:47 PM
cnc's Avatar
cnc cnc is offline
Sorry pic didn't load...yes the actual visible screws on the lower section of the panel...I have the 2 inner ones for the cup area ... it's the 3 that secure the panel to the door I have some with washers and some without... all philps head....trying to determine which ones had the washers and which didn't or....I'll re do the pic tonight..appreciate the help
Old 07-11-2023, 01:24 PM
Strange, the pic link loads for me on my PC, but heres the image as a saved jpg that should show what you need, lots of others on a google search for 1973 firebird door panels.
The screws for the panel are the ones with washers, at least on my 72 & most other 70-73 cars Ive seen in person or pics.
Name:	door panel2.jpg
Old 07-11-2023, 06:08 PM
cnc's Avatar
cnc cnc is offline
Lol,,,,when I meant pic didn’t load it was my pic of my car panel….lol
Ok so the washers are the ones for the lower panel…appreciate the help…..thanks
The Following User Says Thank You to cnc For This Useful Post:
