| Midwest Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin |
Many improvements since Terry & Cori McMillen took over the track.
SuperPro/Top, Pro/Modified and Sportsman/Street race classes. Chief Trophies to the winners plus payouts. The Amazing Arrowhead Low E.T. Trophy for the Quickest Pontiac Powered Entry in Eliminations. 9 Pontiac Classes and 3 Open Classes for the Car Show. No Swap Meet this year. Gates open at 9AM.
Randy Repp 1964 GTO "GoatZilla" 1964 GTO "Injunuity" A/FX Nostalgia Super Stock 220" Rear Engine Pontiac Powered Dragster https://www.facebook.com/PontiacSpeedShop/ https://www.facebook.com/GoatZillaRacing/ https://www.facebook.com/groups/RebuildExcitement/ https://www.facebook.com/Call1844RacersRV/ https://www.facebook.com/groups/INJUNWARS/ |
Short Notice, But I will be there!
Awww snap maybe I'll bring out the 66 if there ain't a cloud in the sky.
Is the Hoosier chapter POCI aware of this?
Hecho en China is not good for U.S. |
Is the street race category a hard tire class? As in no drag radials?
Drag radials are fine
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
Will be their
Is this just a Pontiac race or is it mixed in with the track’s points race? I can’t find much about it. Thanks
You can run both their bracket program and the Pontiac program. Double your chances to win!
| The Following User Says Thank You to GoatZillaRacing For This Useful Post: | ||
I have the drag radials on it now, but my weak point is still the 1310 u joint in the back. I’m nervous about driving that far and having a failure.
If there was a hard tire only class I might opt for that.
Step it up let's go
